Originally posted by Den
tokicos or KYB, how long can they last if they are used with stock spring??
I always hear people lower their car, but they just put on aftermarket spring and using stock shocks. Will the stock shocks be damaged by do this? I really want to know how to set up a good suspension system for my car.
stock strut with aftermarket srping?
after market strut with stock spring?
what's the effect of each combination?
thx~
i dont know how it is for other cars, but the camry's stock struts are not meant to handle all the extra pressure given by lower springs.
hands down, the best combination you can have is both aftermarket springs and struts. the stock struts will eventually blow on lowering springs, because they were not designed to be used at such high compressions.
tokico blues are the highest compression available besides the bilstein/TRD and koni yellow adjustables. kyb's are probably the next highest compression, followed by generic and stock struts.
it all depends on what kind of ride you are looking for.
for near stock feel but better handling, go with eibach/kyb
for the stiffest possible, you will want a race spring with tokicos.
the adjustable koni yellows work wonders, but you have to pay for it
jon
