SPitter and sputter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2003, 07:02 PM   #1 (permalink)
View chumyota's Photo Gallery
SPitter and sputter
89 3sfe. just finished my head gasket job and timing belt. runs good and all but when i gun it from a dead stop she spits and sputters till the rpms get a little higher. i ran premium gas throughher as well as fuel injector cleaner and it helped a little. help me out here. peace
"Life isn't love without a 2 liter."
chumyota is offline   Reply With Quote
Old 05-04-2003, 07:25 PM   #2 (permalink)
View krazeee1707's Photo Gallery
you might want to check your spark plugs and your spark plug wires. I had that problem once, it turned out to be a bad spark plug.
http://www.pbase.com/krazeee1707/lougas_gallery
krazeee1707 is offline   Reply With Quote
Old 05-04-2003, 08:11 PM   #3 (permalink)
V8 POWERRRR
View skperformance's Photo Gallery
probably the timing is off on the crank or cam when the belt got replaced
R.I.P. Dad, Shabeer Khan 11/09/06
Toronto area Lexus Owners Meet My 98 LS My 94 ES
skperformance is offline   Reply With Quote
Old 05-05-2003, 06:43 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Check the ignition system (dist. cap + wires, rotor, coil, and sparkplugs).
Did you line up everything properly when you put the camshafts and timing belt back on?
The camshafts should be lined up to each other by the first set of marks. Theres 2 sets of marks.
The timing belt should be installed with the #1 piston at TDC and the camgear at TDC.
Ignition timing is 10 degrees BTDC.
"Skoolin' the unlearned!"
