CD Player Install: Help Please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2006, 02:58 AM   #1 (permalink)
View simplyxtrippin's Photo Gallery
Tonight. I tried to switch my cd player with the player from my othet car because the older one was not playing burned cd's. I got everything to work except for one thing, maybe two.
When ever i turn on the car, the cd player does not turn on automatically.
the cd player does not keep the set channels that i set up.
there is this wire on oem wires that is yellow and marked, "Memory 12v." i have no idea how to connect this onto the 'newer' cd player. There is also this wire that is coming out of the cd player called, "switched/ignition 12v" The stereo does not turn on if the "memory 12v" and the switched/ignition 12v" are NOT connected.
Questions:
how do i get the cd player to start when i turn the key?
Is it a mistake to connect the two wires that i talked about?
Thanks
simplyxtrippin is offline   Reply With Quote
Old 10-20-2006, 09:33 AM   #2 (permalink)
i hope this helps u understand.
I am not sure where these wires are suppose to connect.
OEM wiring:
memory 12v+
power antenna (i don't think i need this one since my antenna don't move anyways
CD Player wiring:
ignition/switched 12v+
Why doesn't the OEM have the ignition switch?
How did my CD Player hold the memory when it was in my last car?
Thanks
Old 10-20-2006, 10:49 AM   #3 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
Ummm...it's been a while..three or four months.
Um. Easiest for you to do is to use tester. Find the power cables. Turn ignition to ACC and test them. What you are looking for is the constant power source and the Ignition/ACC wire. Which should be gray or red for toyotas.
Then test those two wires you found with the key out.
Hook the one with the constant source to your memory cable to the stereo. The one that only turns on with the ACC hooks up to the regular power.
or ... do the the easy way and go out to a stereo shop or even best buy or circuit city and buy an adapeter if you haven' t one yet=0)
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 10-20-2006, 12:01 PM   #4 (permalink)
thanks for the respond and great information.
but the problem is, the cdplayer that im trying to install does not have a 'memory' wire. and the OEM does not have an acc. wire.
Old 10-20-2006, 12:11 PM   #5 (permalink)
View keithy's Photo Gallery
you can just buy a wiring harness and plug it into the factory harness? The harness should link all the wires and you do not have to worry about cutting and connecting the correct wires.
keithy is offline   Reply With Quote
Old 10-20-2006, 12:13 PM   #6 (permalink)
ok to make it clear again. Even im getting confused with what i am saying. haha.
here are the connections i've made other than the speakers
OEM -------------------------------------------------------CD player
ground(black)--------------------------------------------chassis ground(black)
+12v power (red)-----------------------------------------battery/constant +12v (yellow)
+12v memory (yellowground (black)------------------- ignition/switched +12v (red)
amp turn on (blue w/stripe)-----------------------------connected to amp
power antenna + (blue)----------------------------------not connected
Im guessing that, looking from the CD plyer point of view, that i need to switch the 'battery/constant' with the 'ignition/switched'
is this correct?
Old 10-20-2006, 12:18 PM   #7 (permalink)
i have the harness because, i guess the cd player that is already there is an old after market that does not play burned cd's. So i cut the cd player from the harness. Then i tried to connect the 'newer' cd player onto the harness.
Old 10-20-2006, 12:59 PM   #8 (permalink)
Gameroom cash: $304355
"Im guessing that, looking from the CD plyer point of view, that i need to switch the 'battery/constant' with the 'ignition/switched'
is this correct?"
I think you are correct.
Mike
Old 10-20-2006, 01:16 PM   #9 (permalink)
Thumbs up
awesome. it works. thanks to everybody that helped out. Everything seems to be fnie.
Ill let you guys/gals know if my car burns down. haha. i hope not. that would be terrible. *knock on wood."
thanks again for the help. i love this place.
Old 10-20-2006, 01:18 PM   #10 (permalink)
is this correct?
shouldn't it be the other way round?
+12v power (red)----------------------------------------- ignition/switched +12v (red)
+12v memory (yellowground (black)-------------------battery/constant +12v (yellow)
reason I say that is because after you turn off the ignition, you still need to supply power for your cd player to keep the memory. hmmmm......... anyone can answer this?
Old 10-20-2006, 01:50 PM   #11 (permalink)
yeah. mike cleared that out. thanks
cd player install 99 rav4 geogirl95 Audio, Video, and Security - Tech 0 01-06-2005 04:27 PM
Can you show me install CD player for Corolla 2000 foryou Audio, Video, and Security - Tech 1 07-28-2004 10:20 PM
cd player starchildb4u Archived Corolla threads 12 05-10-2004 11:01 AM
prob. with OEM CD player in 2002 camry undrcroft Audio, Video, and Security - Tech 1 05-03-2004 01:59 PM
