Check Eng Icon-Now What??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2003, 09:26 AM   #1 (permalink)
View Slocrow's Photo Gallery
Yesterday the check engine icon came on. How do I find out what is being referenced by the light. Can I somehow count the flashes of the icon to read a code? If so how? What's my next step? A 93, V6, XLE with 120 on the clock..Thanks, Frank
Slocrow is offline   Reply With Quote
Old 05-06-2003, 01:54 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
First, open the hood and check that your engine is still there.
Second, make sure there isn't anything obvious that's broken.
Third, have it looked at in a shop.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 05-06-2003, 03:20 PM   #3 (permalink)
Well, thanks for the response. I was hoping for a little more like i.e. Jumper the A&B terminals at the computer hook-up, turn the ignition to run and count the number of icon flashes between lag times. Count 12 times first to let you know everything's working then a break followed by 3 times followed by a break and then 2 times followed by a break and then back to 12. Thus reading a code 32 which someone here might be able too decipher as a bad O2 sensor, or whatever. Can you do something like that with Toyota?....Thanks, Frank
Old 05-06-2003, 05:15 PM   #4 (permalink)
OlDsChOoLeR
View FRITO's Photo Gallery
for the 3s-fe engine the 2 then break then 3 blinks is the "air flow meter signal."
"diagnosis: open circuit in e2 or short circuit between vc and vs"
thats what my repair manul says, could be diffrent from generation to gen.
FRITO is offline   Reply With Quote
Old 05-06-2003, 05:40 PM   #5 (permalink)
Frito; Thanks. I didn't mean to mislead anyone. My example was what I'd do for my 91 GM product. I have no Idea what to do for the Camry nor if their is a similar procedure. It appears from your response that there is a Toyota procedure. Could you or anyone explain what the correct procedure is, please. I'll follow the instructions and then report back in an attempt to decipher the reported code....Thanks again, Frank
Old 05-06-2003, 09:19 PM   #6 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Yeah it's possible...you have to jump terminals TE1 and E1. It's in my Haynes manual but I'm not about to type it all out.
But turn your switch to on (without cranking engine) and make sure the car is in neutral. Bridge the terminals...flash two times pause and then flash 4 times will give you code 24. If you have numerous codes, it'll go from lowest to highest code, with a pause in between them. It's a OBD1 system so I'm sure you're familiar with it. In the Haynes manual it's in chpter 6.6.
Good luck!
Silver Streak is offline   Reply With Quote
Old 05-06-2003, 09:24 PM   #7 (permalink)
Banning is an art.
This link has the codes for a supra, should be same for the Camry.
http://www.tigersport.freeserve.co.uk/diag-supra.htm
Or try this...tons of stuff on Google
http://uktoyotaestimasite.tripod.com/obdcodes.htm
Old 05-07-2003, 08:35 AM   #8 (permalink)
Thanks Henry. I'll give it a shot and let ya know....Thanks, Frank
