Is that a Toyota original or aftermarket bar, Whiteline, TRD, or other?
It should have came with a rubber piece to stop side to side movement. My Toyota stock and my Whiteline bar came with them. But you cannot put the stock one on the Whiteline bar I don't think.
Since you dn't have them: you can get some rubber hose that has a similar ID as the OD of bar and two hose clamps that will fit on there. Put a piece of hose wide enough for the hose clamp on the bar and then use the hose clamp to hold the rubber on. Don't grease these parts.
You don't have to tighten down the hose clamp very hard though, just enough to prevent movement.
2007 Camry 2.4L 5M
