Does my 02 XLE hae it? - -Seat belt warning chime - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2006, 05:21 PM   #1 (permalink)
View sundarpn's Photo Gallery
Does my 02 XLE have it? - -Seat belt warning chime
I saw a post here about hot to disable / enable it by holding the trip meter while fastening the belt....
But did not seem to do anything in my carmy ... So is this also not standard an 02 XLE (despite being top of the line..)
Also with regard to the:
- Chirping of the factory alarm, is there a way to change the tones?
- with regard to the trip compuer that shows like Avg MPH etc, is that programmable?
The owners manual is a total waste says nothing.!
sundarpn is online now   Reply With Quote
Old 10-24-2006, 09:16 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
your car should have the seatbelt warning chime... and the reason what you tried didn't do anything, is because there's a procedure to it:
1. turn ignition to ON (do not start, or touch brakes), switch odometer to "ODO" not "TRIP A" or "TRIP B". turn igntion back off.
2. turn ignition to ON (again, do not start or touch brakes), HOLD odometer button for at least 10 sec (recommended 12 sec).
3. while STILL HOLDING odometer button, fasten drivers side seat belt. odometer LCD should now read -boff or -bon upon fastening of seat belt.
4. you may release the odometer button and press it again to achieve desire settings. obviously -boff = belt chime off, and -bon = belt chime on.
5. once you have the desired setting, just let it sit for a while... it will go back to the regular odometer setting.
6. you can now turn ignition back to off.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 10-24-2006, 10:19 PM   #3 (permalink)
Well I tried the same steps and the On / off indicator did not show up. I guess I don' thave it.
the owners manual says that the buzzer will stop after 64 to 8 sec.
I had though that if I did not wear the seat belt and still drove it, I'll get the warning buzzer again as a reminder... when I cross a certain speed
Portion from the owners manual:
This light and buzzer remind you to
buckle up the driver’s seat belt.
Once the ignition key is turned to “ON”,
the reminder light flashes and buzzer
sounds if the driver’s seat belt is not fastened.
Unless the driver fastens the belt,
the light keeps flashing and the buzzer
stops after about 4 to 8 seconds.
Old 10-24-2006, 10:36 PM   #4 (permalink)
Can anyone else with an 02 Camry XLE confirm that the seat belt reminder buzzer/chime does not repeat when you start driving ignoring the seat belt
Old 01-06-2007, 11:21 PM   #5 (permalink)
View marc780's Photo Gallery
I have an 2002 V6. Close enough - ? it has a light that never goes out on the dash, no chime.
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
07 Camry Seat Belt warning chime revhorton 5th & 6th Generation (2002-2006 & 2007-2011) 24 09-02-2007 10:18 PM
List your Gen5 Problems mtnet2000 5th & 6th Generation (2002-2006 & 2007-2011) 61 10-15-2006 07:18 PM
Disable 2006 Camry Seat Belt Chime seanr56 5th & 6th Generation (2002-2006 & 2007-2011) 27 07-27-2006 11:01 PM
