spark plugs change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2006, 10:27 PM   #1 (permalink)
View cam01speak's Photo Gallery
spark plugs change
hi,
i haven't replaced a spark plug so far.
i got NGK OEM plugs (laser platinum) and ngk wire set.
what size spark plug wrench should i buy? it is a 4 cylinder, so everything is pretty much right in front. also, how do i take a wire connection out, both on top of plug and in the distributor (?) box?
is there any step by step anywhere?
newb
cam01speak is offline   Reply With Quote
Old 10-24-2006, 10:30 PM   #2 (permalink)
View sundarpn's Photo Gallery
Not sure about the 01 camry, But I am told that in 02 camry and later, the original plugs are good for 100 K miles
sundarpn is online now   Reply With Quote
Old 10-24-2006, 11:40 PM   #3 (permalink)
View toyomoho's Photo Gallery
The service and on-line maintenance manuals state to change the plugs at 60K to maintain the emission warranty. Although the OEM plugs can easily go 100K.
Remove the spark plug wire boot by pulling up only on the boot end (not the wire). They should pop out. Use a plug socket with a rubber gasket to grip it as you pull it out of the spark plug tube plus an extension. When reinstalling the new plugs apply a little anti-seize compound to the spark plug threads. Torque to 13 lb-ft.
The other end of the ignition wire should be held into the coil by a plastic snap built into the end of the wire terminal.
Old 10-25-2006, 12:36 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If your car is 97 or newer, you have no distributor. Judging by your name, you have a 01.
You can also put some dielectric grease on the rubber where it will contact the plug. This will prevent some sticking.
2007 Camry 2.4L 5M
Old 10-25-2006, 10:50 AM   #5 (permalink)
thx for all the replies. i will try to do that this weekend....
newb
Old 11-22-2006, 09:55 PM   #6 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Exclamation
My engine (my car is in my signature) requires a 5/8" plug socket.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
When to replace spark plugs... MustangDave Camry & Solara Lounge 2 02-01-2006 10:49 AM
spark plugs cam01speak Camry & Solara Lounge 10 01-24-2006 12:27 PM
Spark Plug Change in 98 V6... stir_fry_boy 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-10-2005 06:18 PM
Spark Plugs d0rkiishchris Camry & Solara Lounge 6 08-11-2005 11:09 PM
Spark Plugs Misfiring??? Gen 4.5 Nuke209 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-19-2005 07:20 PM
