sunroof drain tubes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2006, 03:49 PM   #1 (permalink)
View keithy's Photo Gallery
4th Generation sunroof drain tubes
I have a 1998 toyota camry with a sunroof.
I had searched but could not find any info on this. Does anyone know where the sunroof drain tube leads to on the front and back for your gen camry? I am planing to shoot some compressed air into the tubes from the outlet and could not locate the drain tubes. Any help and pics will be appreciated.
I am desperate for an answer. My car is soaked with rain water. please help..........
keithy is offline   Reply With Quote
Old 10-25-2006, 04:35 PM   #2 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Haven't had a need to locate the front ones...so I don't even know if they exist (I have a 99 XLE w/ Sunroof). However, the tubes that lead to the rear of the car travel along the sides of the roof and down the c (or is it d) pillars (the rear most pillars right behind the rear doors (front, middle, rear, you get the idea).
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 10-25-2006, 09:42 PM   #3 (permalink)
Member
View triggerhappy007's Photo Gallery
I'm not sure of the exact location, but it's in between front fender and the front door, at the bottom. Are both sides of your floor wet? If one side is not wet, pour a little water near the front corner of the sunroof and it will drain and you will see. Best thing to do is open the sunroof, spray some air into the holes at the front corners.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline   Reply With Quote
Old 10-25-2006, 10:52 PM   #4 (permalink)
View AmanO's Photo Gallery
I was told the tube goes under the trunk mat on the drivers side. I want to know where the hole is on bottom of the back.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 10-26-2006, 10:55 AM   #5 (permalink)
thanks for the quick reply guys. I tried to look for the drain tubes, but failed to locate them. Worked on it till 2.00 a.m yesterday. Might have to take the trim out from the A pillar and see if I can locate them.
Old 10-26-2006, 11:35 AM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Kathy just blow 20psi of air into the holes in the sunroof (Then 40 if you still have a problem). The drain holes are located in every corner.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-26-2006, 02:08 PM   #7 (permalink)
Gameroom cash: $304355
There is a generation 4 manual stickied at the top of this General Camry Discussion forum. Download it and check the section on the sunroof. It should have a diagram of the sunroof along with the drain holes.
Mike
Old 10-26-2006, 02:43 PM   #8 (permalink)
Mike
I already did that. I am trying to find where the drain tube outlet is. not the INLET. I have heard horror stories about blowing compressed air in the inlet and the tube ended up disconnected from the plastic piece.
Old 10-26-2006, 03:42 PM   #9 (permalink)
Del The Funky One
Delay_FTB's Avatar
The end up behind the wheel wells in the trunk and let out under there, I assume. Try to access the stock-jack area(s) in the trunk and you should see a hefty clear plastic/rubber tube.
Still clueless on the front ones though.
Need pics of sunroof drain holes for Gen 4 stockcammy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-19-2010 03:07 PM
Oil Filter Drain Plug timpearson26 2nd Generation (2005+) 94 08-08-2007 01:43 PM
sunroof type? keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-13-2006 03:26 PM
okay to tighten spark plug tubes (valve cover is off)? 97&02camryleI4 Camry & Solara Lounge 4 07-10-2006 02:12 AM
The sunroof pop TSB toyota_tech_01 Scion Forum 4 11-05-2004 01:07 PM
