Help with neon lights?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2002, 06:27 AM   #1 (permalink)
View GreCam96's Photo Gallery
Can someone tell me how to install my neon lights including where to get powerand how? thnx...
GreCam96 is offline   Reply With Quote
Old 01-06-2002, 07:15 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Read my reply to your other post about wiring up neon lights.
"Skoolin' the unlearned!"
Old 01-06-2002, 03:31 PM   #3 (permalink)
thnx man.. but I have on emore question.. how do I hook up 4 neon lights to the 12 volt power supply won't it overload or burn out or short circuit the electrical systems??????
Old 01-06-2002, 04:02 PM   #4 (permalink)
View critikal's Photo Gallery
If your talking about the 12 volt power supply in your car, like say for me, I used my cigarette lighter wires, it wont overload it at all. I dont know which lights your using but the mini neon lights are only 1/2 amp to an amp and the biggest one streetglow sells is only 4 amps. It wont hurt it, If anything, blow a fuse.
critikal is offline   Reply With Quote
Old 01-06-2002, 04:26 PM   #5 (permalink)
but i don't want to blow a fuse.. got any other suggestions or directions on istallation of neon lights like whihc wires to which?
Old 01-06-2002, 06:18 PM   #6 (permalink)
9thGen Corolla
karma's Avatar
View karma's Photo Gallery
if u want u can hook them off an independant power source, i.e. the battery, run in inline fuse and a relay attached to the ignition of radio or somethin so that when u turn on the car or radio the lights come on automatic and turn off with the car. then i think u can run a switch on it also that way it can be triggered by the car starting but u can still turn it on or off manually. i think thats a way to do it, thats how it is on my fogs......but whatever u do LISTEN TO 88LE he knows his Sh*t When it comes to electronics and my car i go with what he says(hehhe he does all my electrical stuff) and nothing ever goes wrong and it alwayz looks professional.
jes a suggestion
karma is offline   Reply With Quote
Old 01-07-2002, 09:09 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
No. Thats why I told you to use a 12V automotive relay so that you don't draw to much current through the wire that goes to the cigarette lighter. The relay is for safety and i'd rather be safe then sorry.
The +12V wire of the cigarette lighter is used to just trigger the relay. The neons still draw their power directly from a constant +12V source (87 on the relay).
This is how it works. When the relay sees +12V on 85 or 86 (the coil inside the relay) it switches and connects 87 (+12V constant) to 30 (output). 87 is normally open to 30 unless something triggers it (+12V on 85 or 86).
_________________
88 LE (Team C-Spec)
Team C-Spec & Team Quality Control - Master Technician
Powered By ? (Secret project in the works)
"Boost 0wNz j00!"
<font size=-1>[ This Message was edited by: 88 LE on 2002-01-07 12:06 ]</font>
Old 01-07-2002, 09:43 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Some corrections here bro. You don't want to hookup the neons directly to the battery. If you do you defeat the purpose of using a relay.
87 on the relay goes to the battery (constant +12V source) though.
You could run a fuse inline with the constant +12V wire going to the relay for safety reasons. Just incase that wire shorts to ground or something.
If you want them to turn on and off with the radio you would use the amp turn on lead or power antenna lead to trigger the relay.
The +12V wire of the cigarette lighter is a switched source so it acts just like the ignition. So the neons will turn on whenever the ignition is on and turn off when the ignition is off.
If you use the radio to trigger the relay you won't need a switch cos the on/off button the radio acts as one. :smile:
If you use the cigarette lighter or ignition you would need a switch if you want to be able to turn them on and off manually.
Hehe.. Thanks for giving me props bro.
Just sh*t I picked up from taking Electronics in college and working as an installer at my buddies shop.
Corner Lights How do you spell Kamri? Camry & Solara Lounge 4 07-25-2002 05:01 PM
Neon Powers gqdabien Camry & Solara Lounge 4 07-16-2002 08:42 AM
Headlights and Tail lights Siggy Camry & Solara Lounge 5 07-07-2002 10:58 AM
Black Neon Lights blueTRDcamry Camry & Solara Lounge 8 06-03-2002 09:32 PM
install neon lights for a 96 Cam GreCam96 3rd & 4th Generation (1992–1996 & 1997–2001) 14 01-10-2002 04:01 PM
