Dead Battery/Charging system question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2006, 10:28 AM   #1 (permalink)
View wjchun's Photo Gallery
Gen5 Dead Battery/Charging system question
Hi,
I should've made my post here instead of the CAM GEN 5 area.
I've got a 2004 Camry LE still under warranty until December 2006. The battery recently went out. It looks like the battery has been boiling over for a few months. I replaced the battery with an aftermarket and the car works find(didn't want to deal with the hassle of towing the car to the dealer at night). Also, I checked the voltage with no load and with the car running to make sure the alternator was charging the battery, alls seems fine.
My question. Is it worthwhile to have the charging system checked out by the dealer? I'd hate for the battery/charging system to potentially conk out on me once the car is out of warranty.
Thanks!
Warren
wjchun is offline   Reply With Quote
Old 11-03-2006, 11:06 AM   #2 (permalink)
Answered my own question
I called the dealer. They said that they have only seen it twice where the alternator was the culprit for a burnt out battery. It was for a car that had 300k miles and another car with 1000 miles. So...it was just a dead battery.
Old 11-03-2006, 12:10 PM   #3 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ You do know your batter was probably still under warentee, right?
Toyota Brand Batteries are the best I have ever uses. My old Camry and my Dad's amry both have the OEM Battery last 8 years.
5 Lug Corolla WHAT?
Old 11-03-2006, 01:14 PM   #4 (permalink)
Gameroom cash: $304355
2 thoughts come to mind after reading your thread.
First, you can check the charging system yourself with a DVM. Just set the meter to 20 volts DC, start the car, and touch the 2 leads to the battery terminals. You should see up to 14.7 volts. Anything over that and the alternator may be overcharging the battery.
Second, I have seen the internal regulator go out in some alternators causing the alternator to overcharge the battery. However, when this does happen, it is usually accompanied by some of the car's light bulbs burning out. If you haven't had to replace any light bulbs lately, you are probably OK and it was just a defective battery.
Mike
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Question for anyone with a big system or lots of accesories LiquidClen 2nd Generation (2005+) 26 08-15-2006 09:20 AM
2004 Camry VIP system question PowerPC 5th & 6th Generation (2002-2006 & 2007-2011) 6 06-01-2005 02:58 AM
Alarm System Question o0black0o Audio, Video, and Security - Tech 1 05-13-2005 06:50 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
