Fuel Filter Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2003, 10:50 AM   #1 (permalink)
Mobbed Out Camry
View BustaRice's Photo Gallery
My car has been feeling a bit sluggish, slow throttle response, and hard pressure on the gas pedal at times. I've recently poured a bottle of Valvoline fuel injector cleaner and it helped a bit but the guy at autozone said I might need to change my fuel filter if the cleaner didn't work or not as well.
If you guys think my fuel filter would be the problem on the car being sluggish and so than does it matter which brand? Because Kragen has one for $12 but autozone has one for $17 and $35 around, so I'm not sure what the price differences will actually make on the car.
I have a 98 v6 cam btw, any help would be appreciated, thanks.
BustaRice is offline   Reply With Quote
Old 05-12-2003, 12:50 PM   #2 (permalink)
jdv
Been there, and done it.
View jdv's Photo Gallery
i would buy the one from the dealer. i had to go through 3 knockoffs because they all leaked. so much for saving a few $. while at it i would change the air filter and clean the throttle body.
jdv is offline   Reply With Quote
Old 05-12-2003, 12:58 PM   #3 (permalink)
Mobbed Out Camry
can you tell me the steps on removing (if needed) and cleaning the throttle body? and what to use to clean it with, thanks.
Old 05-12-2003, 03:04 PM   #4 (permalink)
jdv
for any vehicle:
- unclamp/unscrew the pipe and air filter housing (the big black box with the round black pipe to it going to the engine)
- unplug the maf (it should be somewhere on the intake, either on the pipe, air box or further to the engine)
- use intake cleaner/carb cleaner. it's a spray you can buy at most car shops. there are too many brands of these but they should all work the same.
- assuming you have all the plastic and sensors in the way unplugged, you will see the throttle body (the metal round thing attached to the engine) spray it with the cleaner. repeat. wipe, scrub with paper towels whatever. be sure you dont leave lints. spray until it is clean (no sooth coming out)
- unplug the throttle cable and open the butterfly. spray it and you might want to scrub it to get the inside edges. keep repeating until clean.
- for severely dirty tb you might need to pull the whole thing off the car and clean all the little holes and pipe inlets in it. i had to do with mine but i live in dust and mud central.
you can see below what my tb looks like. and you can also see the dirt. which can cause idle/power/smoothness issues.
Old 05-12-2003, 05:17 PM   #5 (permalink)
Bring it !
View WickedGen3's Photo Gallery
Originally posted by jdv
for any vehicle:
dude.. thanks for the info.. i just bought this K&N filter cleaner.. will it work.. do i have to re-oil the tB also? and do i have to keep cleaning deep inside.. where the screws are..? or even past that??? man.. my car's been idling rough ! .. and i was looking for ways to clean it.. but didn't know how.. thanks JDV
WickedGen3 is offline   Reply With Quote
Old 05-12-2003, 08:53 PM   #6 (permalink)
Mobbed Out Camry
ya i cleaned it out pretty good... i really feel a noticeable difference in acceleration and throttle response now. now just fuel filter and i'm set.
Old 05-13-2003, 01:30 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The K&N filter cleaner is for cleaning air filters not throttle bodies.
You want to use carb / throttle body cleaner. Brake parts cleaner will work too.
"Skoolin' the unlearned!"
