Cold start-up noise (5S-FE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2006, 07:41 PM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
My dads 96 Camry has developed a nasty knocking noise comming from around the oil pump crank pulley area. It does it only when its been sitting and cold.
I can hear it loudest (mechanincs stethoscope thing) when you rest the tip on the timing scale on the timming belt cover, He says it started after Toyota changed the timming belt for him a few months back, all they changed was the belt NOT the water pump or the tensioner, or any seals....
Any ideas what this could be, or does anyone have a picture of the engine around there so i could dianose better?
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-06-2006, 12:16 AM   #2 (permalink)
View toyomoho's Photo Gallery
Go to the link below and find the service info for the year/engine type. Might listen in the water pump area, it goes bad much more frequently then the oil pump. How many miles on this engine, have any other parts been changed over times such as water pump, idler pulleys, etc?
http://oregonstate.edu/~tongt/camry
Old 11-06-2006, 02:35 PM   #3 (permalink)
View kamrhee's Photo Gallery
4th Generation
94_rolla_guy,
If you have time, try removing the upper timing belt cover. This could verify if the timing belt slaps the lower timing belt cover. That's what happened to mine when I changed the timing belt and water pump. Its a tedious process to remove but worth it to see if that is really the case.
kamrhee
1998 Camry LE 5s-fe (Stock)
2002 Toyota Highlander 1mz-fe (Stock)
My other car is a Bianchi
kamrhee is offline   Reply With Quote
SMOKE on cold start thetailwind MR2 Forum 7 11-23-2005 11:04 AM
Recaros Start seats are now just $195.95! Buy last years close out fabrics and save! Safe Drives Supporting Vendor Sales 0 11-09-2005 07:17 PM
Cold start issue. steadyeddie Camry & Solara Lounge 1 07-29-2005 11:18 AM
Cold start problem/hesitation drdma Celica Forum 3 10-03-2003 03:36 PM
Weird engine noise on cold days CBerten Celica Forum 2 11-17-2002 08:16 PM
