On 2002-01-07 19:38, SGG wrote:
hey guys, I should've thought of this while I was staring at your cars! The original gen3 grills have a horizontal fin halfway up, right? Did you guys just cut those out, fill in the holes and paint?
jon
Yes, that's exactly what I did. Not only the horinzontal ones, but the vertical ones and the center logo as well. Just use and small saw, or a Dremel if you're confident, to cut everything out. Make sure you pre-mark your cuts. What I have also done is to make the grill more shallow so the mesh won't sit as far back. You can then drop it off at the shop for the filler and paint; or like Henry, a complete DIY.
I believe Ratko has a picture of the latest iteration of my grill from the last time we met up. Please post it if you can, Ratko.
That's my 2 cents. Hope that helps, GreCam.
