All the screws you need to remove are labeled in the pic above. I don't have a pic of the drivers side but, the screws are in the same spot.
The door handle is kinda tricky to remove. After you remove the screw, slide the whole thing forward (push on the plastic in front of the metal handle). You'll feel it unclip. Then you can kinda pull it out.
The next part is a pain in the a**. Behind the handle (inside the door) is a metal rod. The metal rod is attached to the back of the handle with a clip. You need to reach inside with your finger and undo the clip. After you undo the clip push up on the metal rod to pop it loose. Then you can remove the handle.
The black plastic cover at the top corner just pops off.
After you remove everything pop off the bottom and sides of the door panel, then lift up on the panel. Unplug whatever plugs are behind the panel.
I almost forgot about the light on the door panel. If you have a light on the door panel (mine did) you need to remove it. Its just 2 screws and the whole thing pops out and unplugs. I got rid of mine when I built a panel to replace the map pockets.
