drive axles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2006, 07:46 PM   #1 (permalink)
View standupguy's Photo Gallery
drive axles
Still working on pulling the 2.2 engine on this 2000 camry. I'm down to the drive axles. I pried and pried on the left it wont budge. Is there a trick to removing the axle? Any help is greatly appreciated Thanks in advance.
standupguy is offline   Reply With Quote
Old 11-14-2006, 01:36 AM   #2 (permalink)
View toyomoho's Photo Gallery
If nothing else is holding the axle in place, you will need to pop it out. The CV joint may have a notch for locating one end of the pry bar. Position the bar so as to pry out the joint, then give it a sharp and hard impact. The axle tends to pop out under impact, not pry out like a stuck bolt.
Installing the new axle also can require popping it into place. Position the slot in the spring clip at the bottom. Install the axle into the differential housing then drive it into place sharply with you hands. If unsuccessful, repeat the process. Be sure not to damage the differential oil seal.
Old 11-17-2006, 09:32 PM   #3 (permalink)
HOLY COW! Batman! I've never seen drive axles so hard to get out. But I did it. I guess I was to afraid I was going to bust my knuckles bad. Thanks for the reply toyomoho.
Old 12-02-2008, 01:46 PM   #4 (permalink)
View Betta-j's Photo Gallery
I still can't prop it out...can someone give me more details (my car is a 99 Celica, MT.). This would be for the driver's side (LH). there are some wedges on the cv axle inner joint...just can't get any "lock" on to it with a pry bar or anything else...just slips...
Please help.
Thanks.
Betta-j is offline   Reply With Quote
Feeler post on TW one piece drive shaft group buy. russ25nys 2nd Generation (2005+) 30 04-05-2007 12:32 AM
engine/tranny combos? ninerjoe Archived Corolla threads 2 11-03-2006 09:03 AM
4 wheel drive light MCMIXMASTER 2nd Generation (2005+) 2 10-16-2006 07:29 PM
FS: New Western Digital 160GB hard drive, 7200 RPM, 8 MB Cache skewe Non-Automotive 24 03-16-2006 11:46 PM
