'03 Camry won't shift out of 'Park' - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2006, 03:59 PM   #1 (permalink)
'11 Camry SE Sport
View carrlos's Photo Gallery
Gen5 '03 Camry won't shift out of 'Park'
My '03 Camry won't shift out of park unless I take out the plastic tab next to the shifter and push the button inside. Besides that , the brake lights are not working. I think they are both related to a switch or sensor connected to the brake pedal that may not be functioning. I'd appreciate some help on how to fix it.
carrlos is offline   Reply With Quote
Old 11-16-2006, 07:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
Your logic is sound. Most likely the brake light switch is not working. Improperly adjusted, broken, wires disconnected, fuse blown. The brake light switch needs to work for the transmission lockout circuit to work. Look under the dash at the top of the brake pedal to find the switch.
Old 11-20-2006, 06:27 AM   #3 (permalink)
'11 Camry SE Sport
Thanks, toyomoho, for the information about this problem! The culprit was the brake light switch. Apparently it was stuck in the "in" position which signifies "no brake applied". This resulted in the shift lever not being unlocked and no brake lights. I hit it with some heavy grease and worked it in and out several times to loosen it up. As for now, I don't think I need to replace it but I will keep an eye on it.
Old 07-19-2008, 01:07 PM   #4 (permalink)
'11 Camry SE Sport
20 months later and it's stuck again!!!! Let me see if I can find that grease I bought back in Nov '06!!
Old 07-23-2008, 12:56 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Are you kidding?
Just replace it.
2006 Camry LE Special Edition
Old 02-18-2010, 12:09 PM   #6 (permalink)
View Cerritos's Photo Gallery
If you can post a picture, it would be great.
I'm having the same problem. I don't know which one is the problem switch.
Cerritos is offline   Reply With Quote
Old 02-18-2010, 12:44 PM   #7 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280592
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 09-25-2011, 07:48 PM   #8 (permalink)
View hor65's Photo Gallery
2004 Toyo Tacoma won't come out of park
I had the same problem with toyota Tacoma 2004 that would not come out of park.
After reading the post, I checked the brake lights and found that the taill light fuse was blown....most likely when I hooked up a trailer and lights.
I replaced the fuse and all works fine now.
Thanks for the info!
hor65 is offline   Reply With Quote
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Wont shift out of park? CarsAndMore 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-20-2006 06:26 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
