Head Gasket Gone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2006, 11:04 PM   #1 (permalink)
View 3S-FE-helpPleez's Photo Gallery
Question Head Gasket Gone?
Hi Guys, I wonder if someone knows the answer to this riddle?
1. '96 3S-FE with 240th Km uses water but none in the engine oil - also radiator is OK
2. Water reservoir keeps getting "rust" lining despite coolant in use
3. Spark plugs are swimming in oil
Is there possibly a leak beteen the head and the exhaust manifold?
Do I need to replace the head gasket?
3S-FE-helpPleez is offline   Reply With Quote
Old 11-16-2006, 11:31 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
#3 valve cover gasket and spark plug tube gaskets try replacing those 2 first and see...
#2rust replace the radiator it's probbly rusted out... or try a radiator flush first
Old 11-17-2006, 04:34 AM   #3 (permalink)
View toyomoho's Photo Gallery
The water could be going out the exhaust pipe as steam. Is the water pump or hose leaking? You might do some tests such as compression or leak down. Drain a little coolant out of the radiator and see what the cooling tubes look like. Is the coolant old? Sometimes the interior of the coolant overflow hose breaks down and leaves a blackish material. Do a TN history search as the subject of blown head gaskets and how to diagnosis them has come up many times.
Old 11-19-2006, 09:35 PM   #4 (permalink)
View thisisntjoew's Photo Gallery
3rd Generation
The oil on the top of the plugs is most likely from the valve cover tube seals.
3rd Gen/5s-fe/Camry
thisisntjoew is offline   Reply With Quote
Blown Head Gasket? Block Seal? 89_3SFE Camry & Solara Lounge 11 07-20-2006 12:09 PM
metal head gasket for a 4afe woodenhead72 Archived Corolla threads 9 07-12-2006 11:22 AM
1993 4 runner head gasket blown! peanutzz 4Runner Lounge 4 02-15-2006 10:45 AM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
