Strange sound at the tiime of accelearation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2006, 08:21 PM   #1 (permalink)
View wildgaon's Photo Gallery
Australia Strange sound at the tiime of accelearation
Hi all , I have camry 96 ,98k miles. Every thing is fine. Today i drive 90 miles one way it works fine, but at the time of return when i startted it, it is giving a unpleasent sound. Specially when i accelerating a huge sound was coming it is like a some silencer missing type not sure.
But when it started running 60-70miles sound disappers. I drive 65 miles, tha stopped at one place for 5-10 mints. At the time of starting same sound was coming again...It seems sound is coming from engine hood.
I am bit disturbed . Otherwaise car is running fine..
Can any body give some suggestions... I am also not very familiar with car sounds and engine working..
Thanks in advance
wildgaon is offline   Reply With Quote
Old 11-18-2006, 12:15 AM   #2 (permalink)
View toyomoho's Photo Gallery
What engine does this car have? Next time it happens, open the hood and try to narrow down the area the noise is coming from. Front, top, side, exhaust system, etc.
Old 11-18-2006, 10:12 AM   #3 (permalink)
Thumbs up strange sound
My engine is 2.2 liter.
I further diagnosed that sound is extra to engine sound like"dhak-dhak", majority heared from top air intake side.. It seems that some exhaust leak but i can not make exactly from where it is coming.
as per your experience let me know ,where i have to search . I couldnot go under the car as i do not have ramp...
Please advice
Old 11-18-2006, 03:05 PM   #4 (permalink)
You do not need to get under the car to do most of the investigation work. The exhaust manifold comes out in front of the engine. The exhaust pipe connects to this, and then runs under the engine and car. The front of the exhaust manifold system is shielded with thin metal plates.
The manifold can leak at the joints or sensors going into the system. There is an exhaust pipe flex link under the car, right about where the front seats are. This link is a very common point of exhaust leakage. It looks like a pipe made out of wire. The other less common location is where the exhaust pipe bolts to the manifold system. The manifold system incorporates a catalytic converter in addition to running to each cylinder.
It may be possible there is problem with the air intake system, such as the filter box. The air intake system is designed to muffle the noise of the air going into the engine. Since the noise seems only to accrue when accelerating, it may be a problem in this air intake system. As the car runs OK, the problem must be before the throttle body. This is the part on the intake system where the throttle cable attaches to a pulley.
Pipe up a length of rubber hose to use a stethoscope and help run down the exact leak location. If an exhaust leak, you may be able to feel the exhaust coming out of the leak. Of course be careful, as the system is very hot.
Download the service manual for this Generation of Camry (Gen 3) engine from the link below:
http://oregonstate.edu/~tongt/camry
This will give you an idea of the engine system design. Where the joints are in the exhaust system, air intake system, etc.
Once you do this, you have a better idea where to look for the leaks.
strange whistling sound en1gma Camry & Solara Lounge 8 05-24-2010 01:19 PM
sound system Seiwoong Archived Corolla threads 8 09-16-2005 01:03 PM
Performance Auto & Sound Magazine's Canadian Nopi Nationals Tour 2005 PAS Events Regional Meetings and Events 0 07-26-2005 12:17 AM
Finally got the sound that I was looking for. (Exhaust) trdspeedwayblue 2nd Generation (2005+) 21 07-17-2005 02:05 PM
Hollow Clanking Sound MetalMatrix Camry & Solara Lounge 2 07-13-2005 11:05 PM
