What you described, trdcamry2003, is for an A/T, not for M/T.
Aypstony, there should be a 10mm hex bolt drain plug on the transaxle, and as what is written in my Haynes about filling:
1) The manual transaxle does not have a dipstick. To check the fluid level, raise the vehicle and support it securely on jackstands. On the lower front side of the transaxle housing, you will see a plug. Remove it. If the lubricant level is correct, it should be up to the lower edge of the hole.
2) If the transaxle needs more lubricant, use a syringe or a gear oil pump to add more. Stop filling the transaxle when the lubricant begins to run out of the hole.
3) Install the plug and tighten it securely. Drive the vehicle a short distance, then check for leaks.
Torque setting on the manual transaxle drain and filler plugs is 36 ft-lbs. Manual transaxle needs about 2.7qts of API GL-3, GL-4, or GL-5 75W-90 gear oil.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
