Passenger headlight and dome light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2003, 03:50 AM   #1 (permalink)
View CamryLE1994's Photo Gallery
Hi- I cleaned my throttle body today. Took it out and cleaned it thoroughly. Then I notice tonight my passenger headlight doesnt work and the dome light doesnt work on the "door" position. It works on "on" and "off". Is there a fuse blown? Could I have messed up some wiring?
TIA
CamryLE1994
CamryLE1994 is offline   Reply With Quote
Old 05-17-2003, 04:55 AM   #2 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
Chances are good that it's just coincidental. Pull the headlamp bulb out and see if the filament's burnt off. Try NOT to touch the bulb in the process.
As for the dome light not working, look at the dash when your door's open to see if the "opened door" indicator light is on or not. If not, then it's a problem with the sensor on the door. Try to narrow it down to a particular door, if possible.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 05-17-2003, 07:33 PM   #3 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
If you narrow it down to a specific door, you should just be able to wiggle the sensor around, and hopefully it'll go back into it's correct place and work like a charm.
nort0188 is offline   Reply With Quote
Old 05-17-2003, 08:31 PM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
for your year I dont think headlights and dome light are on the same fuse... for me it was the dome, stereo, clock and trunk light on the same fuse.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
