02 Camry Fuse Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2006, 10:53 PM   #1 (permalink)
View aair2002's Photo Gallery
I have a 2002 Camry that has had the 120 amp alternator fuse burn out. I tried pulling out the fuse and the studs from the fuse remained in the holder and will not come out. I have tried and tried to remove the remining studs and they will not come out. Desperately need help!!!!!! Any appreciated.
aair2002 is offline   Reply With Quote
Old 11-25-2006, 02:12 AM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Sorry to hear that... the only thing I can think of is to just use tweezers or something if you can get 'em in there to pull it out.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 11-25-2006, 05:38 PM   #3 (permalink)
View toyomoho's Photo Gallery
Some Toyota alternator fuse holders appear it to come out, allowing access to the backside. You could then push the pins out from the back. The backside of the fuse box itself should come off, this requires unbolting it from the frame. Make sure you remove the battery cable before working on the holder.
Old 11-28-2006, 04:36 PM   #4 (permalink)
Fuse Fix
Thanks for the replies. Neither one worked. Come to find out the fuse has two screws holding it in place from the side. The fuse panel box must be removed and the two screws removed in order to remove the fuse. Very poor design if you ask me.
EFI fuse problem please help nick4runner 4Runner Lounge 1 05-31-2006 09:00 PM
98 Taco Fuse Problem Kawika 1st Generation (1995.5–2004) 0 11-09-2005 08:42 PM
02 Camry Se Cat Converter Camuser15yrs 5th & 6th Generation (2002-2006 & 2007-2011) 0 10-20-2005 07:02 PM
Short Circuit Fuse Problem 2005 Camry XLE Phenocain 5th & 6th Generation (2002-2006 & 2007-2011) 5 09-13-2005 09:42 PM
Toyota Camry 1993 V4 short circuit problem steaua 3rd & 4th Generation (1992–1996 & 1997–2001) 6 05-04-2005 04:49 PM
