electrical gremlin
Just curious if others have had to deal with the following issue and what the culprit ended up being in hopes that I can fix the problem a bit quicker.
In Feb. I had my alternator replaced and the battery was new in Dec. The other day the car died in much the same way that it died when I lost the alternator...the idiot lights came on, stuff started working slowly and then at a stoplight it was off.
There were a few differences between Feb. and the other day. The obvious one is the alternator is now new. According to the mechanic the neutral safety switch is on its way (the only symptom of this is that the 'N' indicator on the dash is always lit along with whatever gear I'm actually in). The heater stopped blowing warm air. And, most importantly, it took me 20 minutes to jump it this time. To drive the last 1/4ish mile home I had to jump the car 3 times all 3 took 15 or 20 minutes.
So, the next day, Sat., I jumped it and took it the local parts store with free electrical system testing and the alternator was putting out between 13.2 and 14.0 volts, a bit low but I wouldn't think that it would have lead to the problems I had had the day before. I had already made an appt for the mechanic for, what is currently, yesterday morning, monday. The mechanic found normal charging and no electrical issues. On my way home last night I got a couple of brief, 2 or 3 second, flashes from the idiot lights and then that was it, it made it home no problem, other then a little added stress.
So, does this sound familiar? What was found on your car?
1990 Camry V6 LE loaded
