oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2003, 01:43 PM   #1 (permalink)
View yrmac's Photo Gallery
oil filter
I would like to increase the size of my 5s-fe oil filter for better engine protection plus an added increase in oil capacity. Does anyone know a bigger oil filter that will fit the 2.2L Camry engine? Someone told me that the oil filter for 2001 Celica GT-S is taller than the filter for the 2.2L Camry engine, thus it has a more surface area and it will fit the 2.2L. Anyone tried using this Celica oil filter before or the better question is, will it fit?
yrmac is offline   Reply With Quote
Old 05-22-2003, 10:41 PM   #2 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
I can't imagine it would be that much bigger. What exactly would it do? More oil would help you out how? Maybe you could go longer between oil changes since you've got more to use? I don't really see how much more oil you would actually gain... maybe a quarter of a quart?
nort0188 is offline   Reply With Quote
Old 05-23-2003, 06:22 AM   #3 (permalink)
Bigger filter=bigger surface area and holds more oil. Bigger surface area= better filtration. More oil= increase in lubrication in the engine. Better filtration+better lubrication= better engine protection + longer engine life. Even a half litre makes a lot of difference for the engine. 500ml= 14% increase in the total volume of oil that is available for the engine. I think this is significant especially for a Toyota engine that is famous for sludge build up.
Old 02-28-2004, 10:57 PM   #4 (permalink)
View freeyellow2000's Photo Gallery
Does anyone know if I can use 1MZFE Camry (V6) oil filter on a 5S-FE Camry engine (i4)? I have quite a few of oil filter for 1MZFE engine and who hate for it to go to waste.
Has anyone does this before? If so was there any problem?
freeyellow2000 is offline   Reply With Quote
Old 02-28-2004, 11:09 PM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
for a while now i've been using a larger filter on my 3vzfe, i just take the stock one, and compare the diameter to others in the store, works fine for me
-Nick
Nick is offline   Reply With Quote
Old 02-29-2004, 03:11 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: oil filter
90915-YZZA1
"Skoolin' the unlearned!"
Old 02-29-2004, 10:49 PM   #7 (permalink)
www.whomikejones.com
View dan99solara's Photo Gallery
i agree with you 110%. i used to use an acura nsx oem filter for my acura legend because it was a lot larger than the ones for the acura legend. this increased my oil flow especially at high rpm. at high rpm on some small fram (or other bad aftermarket filters), some oil actualy gets skipped and does not get filtered.
1999 Pearl White Solara
5-Speed 3.0L V6
K&N drop-in filter
dan99solara is offline   Reply With Quote
