low idle at cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 11:31 AM   #1 (permalink)
View q.man06's Photo Gallery
alright, it seems to me that there is a valve or something that needs cleaned out.
I'm not too familiar with toyota's and it would be nice to get some help as to what may be the issue.
instead of idling at 1000+ rpm on a cold start, it goes right to 700-800 where it sits steady.
Any ideas?
q.man06 is offline   Reply With Quote
Old 11-30-2006, 04:43 PM   #2 (permalink)
Gameroom cash: $304355
Clean the idle air control valve. You can get to the passage leading to the valve inside the throttle body. Remove the big rubber tube leading to the throttle body and at the base of the throttle body you will see a square or diamond shaped hole. That is the passage leading to the throttle body. Spray throttle body cleaner or oxygen sensor safe carb cleaner liberally down there and let it soak for 5 or 10 minutes. You can clean the rest of the inside of the throttle body while you are waiting. If you are not familiar with how to do this do a search on this forum for "throttle body cleaning". There have been numerous posts about it on this forum.
Mike
Old 11-30-2006, 08:40 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Try checking the cold start time swtich, or the engine coolant temp sensor also.
My ECT sensor was slightly unplugged once and when started cold..it idled low...at 600-700rpm on cold start..plugged it in again a wallah!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-30-2006, 11:11 PM   #4 (permalink)
where is the ECT located on the 2.2L?
and i've definatly cleaned out TB's before, but i wasn't sure if there was a cold start valve i needed to check out and/or replace.
Thanks for the info so far, keep it coming
Old 12-01-2006, 01:15 AM   #5 (permalink)
VeeZed
Both are located on the right side of the engine next to the cylinder head (when looking at the engine from front on). There screwed into what is called the coolant bypass pipe. The ECT is the one with the green plug and the cold start time switch is the one with the grey plug.
Excessive Cold idle Speed= More wear msmclean 2nd Generation (2005+) 29 09-23-2006 06:57 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
95 Camry 4 cylinder cold start problem joea 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-31-2005 09:40 PM
98 4 cy. - low idle on start corrinebean 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-02-2004 07:06 PM
Cold start problem/hesitation drdma Celica Forum 3 10-03-2003 03:36 PM
