New spark plugs - lower mileage ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 01:50 PM   #1 (permalink)
View cam01speak's Photo Gallery
Unhappy New spark plugs - lower mileage ?
i changed spark plugs on my 2001 camry 5s-fe last month. got OEM ngk laser platinums and ngk wireset. somehow i noticed that i am not getting the mileage my factory installed used to give. did any of you had similar experiences? is there a solution to this?
newb
cam01speak is offline   Reply With Quote
Old 12-03-2006, 02:22 PM   #2 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Measure the resistance of your old wireset vs your new wireset. Which one has the correct resistance?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 12-03-2006, 04:38 PM   #3 (permalink)
Gameroom cash: $304355
Just a thought. Are you comparing the fuel mileage you are getting this time of the year to fuel mileage measured during the Summer months? The colder the ambient air temperature, the lower the fuel mileage will be.
Mike
Old 12-03-2006, 05:07 PM   #4 (permalink)
What is the correct resistance of the spark plug wire set and how do you measure it (multimeter?) ?
Winter temperatures : i didn't think about that. definitely a factor.
newb
Old 12-03-2006, 06:15 PM   #5 (permalink)
I measured the resistance of my old and new wires. I measured the longest and the shortest. The old one (long) where it said like 10.9 (in 20K setting), the new one is 5.9. The shortest was 5.9 (old) vs. 2.9 (new). I am thinking since the resistivity of the new one is lower than original, that should help, isn't? any thoughts??
newb
Old 12-03-2006, 06:36 PM   #6 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Correct.
I'm of the opinion that most of your situation is related to the weather getting colder, especially if you do a lot of short trips.
DFBonnett is offline   Reply With Quote
Old 12-04-2006, 12:06 AM   #7 (permalink)
View toyomoho's Photo Gallery
I thought Toyota stated the max ohm reading was 25K per wire. Do you still have your old plugs? If so, might swap the old parts back in, then see if your mileage changes. What kind of drop in MPG are we talking about?
Old 12-04-2006, 12:38 PM   #8 (permalink)
2002 Camry
take a good average reading of your MPG
Someone mentioned that readings may vary in the winter and that is a good point. Make sure you take an average before drawing any conclusions the MPG is dropping. In other words, take several readings over a period of a month or so, then you would get a better idea what your average MPG.
Spark Plugs - How hard can it be? 95t100xcb T-100 7 07-28-2007 07:53 PM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 06:52 PM
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-22-2006 11:56 PM
Anyone using Nology Silverstone Spark Plugs TRD_Rob Camry & Solara Lounge 1 03-18-2004 12:28 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
