2000 camery throttle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 06:54 PM   #1 (permalink)
View johnc1's Photo Gallery
USA 2000 camery throttle problem
12/2/2006 88,900 miles
I have a 2000 CAMERY that I just purchased. The throttle seems to have a very hard spot when pressing down. Sometimes it feels like a bad cable. I have grease, oiled, push, pulled everything. I had heard it could be a throttle body problem. Where can I go to find out how to clean the throttle body ? Thanks, John C.
johnc1 is offline   Reply With Quote
Old 12-02-2006, 07:31 PM   #2 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
My car (see my signature) had a sticky throttle right off idle some time ago. A thorough cleaning of the throttle body fixed my problem.
Do a search....gobs of info here on that job, along w/ some nice DIY threads.
Good luck!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 12-02-2006, 07:31 PM   #3 (permalink)
View toyomoho's Photo Gallery
The link below provides access to service info to take the engine apart. Do a TN Carmy search for "throttle body." The results will turn up the hits you need to clean it.
http://oregonstate.edu/~tongt/camry
Old 12-02-2006, 07:50 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Get some throttle body cleaner and spray in the throttle body. Scrub it some with an old tooth brush. Should help out a bit.
2007 Camry 2.4L 5M
2000 camry problem lostpaki2003 3rd & 4th Generation (1992–1996 & 1997–2001) 9 11-01-2006 11:24 PM
problem with camry 2000 tu9l 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-08-2006 09:40 AM
2000 Celica "bogs" Fuel delivery problem? somepersian Celica Forum 3 11-15-2004 09:39 PM
2000 Camry Headlight problem intell 3rd & 4th Generation (1992–1996 & 1997–2001) 1 01-10-2003 10:49 AM
