Removing B pilar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2006, 12:18 AM   #1 (permalink)
View sportivo's Photo Gallery
Gen5 Removing B pilar
Can someone show me how to remove the B pillar on my Gen 5 Camry. If possible with some pics.
Thanks
sportivo is offline   Reply With Quote
Old 12-03-2006, 01:08 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If you want to remove the plastic inside, it's probably just clipped in. Figure out how to remove the two other pieces at the bottom along the door frame and he B-pillar piece should be able to come out. You just have to pull on it to find out where the clips are.
That's the way it was on my Gen 4.
But if you are trying to remove the B-pillar itself...you'll need a saw of some sort.
2007 Camry 2.4L 5M
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Finding and removing airbag memory chip. FBRAV RAV4 Forum 4 08-02-2009 03:27 AM
Removing rear sway bar because of rattle noise. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 13 02-16-2008 05:53 PM
Removing Lenses Illegal in CA? OneMnk 2nd Generation (2005+) 9 02-02-2006 03:46 PM
Removing EGR system White89SR5 Archived Corolla threads 1 12-21-2005 11:11 PM
