HELP! 99 camry with bad air/fuel ratio sensor- AGAIN! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2003, 02:28 PM   #1 (permalink)
View sabbates's Photo Gallery
All-
I've got a 4 cylinder 99 Camry LE with 80K miles.
About 6 months ago, the check engine light came on with "too lean" message, I believe it's error code P0174.
The dealer said this was due to a bad air/fuel ratio sensor (this is what Toyota calls the "oxygen sensor"-like device on the exhaust manifold)
I replaced it, and didn't have any problems until last week.
The check engine light came on again, with the same error code (too lean).
What could cause the air/fuel ratio to go bad so quickly?
Or, does the error message imply something else is at fault?
Thanks for any help,
Sabbates
sabbates is offline   Reply With Quote
