Which should i get...front sway bar, rear sway bar, or both??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2003, 10:12 PM   #1 (permalink)
metamorphosis
cman2000's Avatar
View cman2000's Photo Gallery
Question Which should i get...front sway bar, rear sway bar, or both???
Hi
I recently installed tokico struts and eibach springs, which improved handling greatly. I've also added a front strut tower bar. Now the last part of the suspension upgrade is the front and rear sway bars. if i could only get one, which one should i get? ANd what are the advantages to each? For example, if i only buy the front sway bar, would the rear of my car feel unbalanced? or would a rear sway bar by itself be enough to balance out my car?
if people recommend buying both, then i will do so in the future...but because money is alittle tight, i would rather buy one for now. any help would be great! I was planning on getting them from ctmotorsport.com. the front and rear are $109 each i think.
thanks
mchi5
cman2000 is offline   Reply With Quote
Old 05-29-2003, 10:22 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Most ppl would tend to suggest getting only the rear bar. Beefing up the front bar will only induce understeer, which the car already has a tendency to do. Not only that, the stock front bar is adequate and does the job.
I've got both front and rear bars, as well as a strut brace and I feel balanced. Mind you, I don't really push the car that hard around corners to begin with.
Phi is offline   Reply With Quote
Old 05-29-2003, 10:58 PM   #3 (permalink)
metamorphosis
cman2000's Avatar
hey
thanks phi for the post. i might go ahead and buy the rear sway bar. after my new springs/shocks and front strut bar...the front of my car feels a little "heavy" and the rear feels more unbalanced. so hopefully a rear sway bar will help alot. did you get the whitelines sway bar? or did you get the TRD sway bars?
thanks
Old 05-30-2003, 01:25 AM   #4 (permalink)
View theronin's Photo Gallery
or you could just get both (adjustables) and see if you can dial out the understeer and see if you can get more of a neutral feeling! can you even fine tune sways to do that on your cars guys? that would be the best bet neutral handling! WEEEEE
95 240sx SE
Z32 Brake Swap
VLSD Swap
Fear the Sampan!
theronin is offline   Reply With Quote
Old 05-30-2003, 07:55 AM   #5 (permalink)
View soundlzrd's Photo Gallery
To a point you can, but you have to be able to get adjustable sway bars. We only have the TRD bar avalable to us, so you cant really dial in your handling to much. Oh well, i love my whilteline stuff
Sean
soundlzrd is offline   Reply With Quote
Old 05-30-2003, 09:47 AM   #6 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
I can't wait to install mine !
Lets hope you'll receive them soon
mox is offline   Reply With Quote
Old 05-30-2003, 09:56 AM   #7 (permalink)
You should, i need to check up on the status again
Old 05-30-2003, 11:50 AM   #8 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
You should already have one in the front so just add a rear. If you do add the rear and you find that you are getting too much oversteer you can install stiffer rubber grommets in the front and that will tighten the feel a bit.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 05-30-2003, 12:51 PM   #9 (permalink)
arent the whitelines adjustable? they are for most other applications! is whiteline new to the camry scene?
95 240sx SE
Z32 Brake Swap
VLSD Swap
Fear the Sampan!
Old 05-30-2003, 01:17 PM   #10 (permalink)
No, whiteline has been making sway bars for camrys for as long as i have been modding the camry.
Old 05-30-2003, 01:20 PM   #11 (permalink)
arent they adjustable? i fail to see the problem?
95 240sx SE
Z32 Brake Swap
VLSD Swap
Fear the Sampan!
Old 05-30-2003, 01:32 PM   #12 (permalink)
Not adjustable.
Old 05-30-2003, 05:17 PM   #13 (permalink)
oh that sucks... therein lies the problem!
95 240sx SE
Z32 Brake Swap
VLSD Swap
Fear the Sampan!
