How do I change the LEDs in the AC, Defrost, control on the - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2002, 04:24 PM   #1 (permalink)
View GreCam96's Photo Gallery
Anyone know how I can get to the LEDs on the climate control panels to change the lights??? Also, does anyone know wut kind of bulbs they use???? If anyone knows gimme a Holla!!
GreCam96 is offline   Reply With Quote
Old 01-10-2002, 04:48 PM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I got the same problem... mine come on tho if I turn the vent knob back and forth really fast. :razz:
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 01-10-2002, 06:45 PM   #3 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
hi there just replaced my bulbs in the defroster they were a pain to remove even with the haynes manual.. in each switch there are 2 kinds of lights that toyota uses one is blue ( lower wattage) and the other is black (higher wattage) same kinds as ur dash lights the small ones not the 194 wedges. first u gotta remove and check which bulb u want replaced then u can go to toyota and ask them for that same bulb...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 01-10-2002, 08:31 PM   #4 (permalink)
View soundlzrd's Photo Gallery
Can you change them to LEDs so you can have different colors?
soundlzrd is offline   Reply With Quote
Old 01-11-2002, 11:45 AM   #5 (permalink)
Blazin...
no because the cover that changes the light is inside the switch the u cant change the color if u did it would comeout as the same color as stock which would be expensive plus finding an LED to fit that size of bulbs.. not likely its too small and no wiring in there for u to use only uses contact points to light it up so i dont think its worth ur time to change the lights into a different color
Neoscepter
Old 01-11-2002, 11:09 PM   #6 (permalink)
well thanks, you just saved me alot of time!
Old 01-12-2002, 01:46 AM   #7 (permalink)
Blazin...
anytime dude... but i did ask a few if u want u can change ur dash lights if u're not goin indiglo though..
Old 01-12-2002, 02:39 AM   #8 (permalink)
i dont know, i have sounds soemthings i like for the dash, mostly on ebay, but they say they are not indiglo. Im not sure, to much stuff, so little cash
<font size=-1>[ This Message was edited by: soundlzrd on 2002-01-12 03:39 ]</font>
Old 01-12-2002, 10:39 PM   #9 (permalink)
thnx
Will automatic AC climate control unit work on mine? Jay Camry & Solara Lounge 2 06-12-2002 08:16 PM
