changed springs, but rattling noise in the right rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2003, 09:58 PM   #1 (permalink)
Bollywood Boy
mrbacardi's Avatar
View mrbacardi's Photo Gallery
hey guys, i just finished changing my springs by myself a couple days ago, but, it started today, when i go over a bump or something, i hear a really loud rattling noise, basically, whenever the car is shaking, the noise comes, does anyone know the cause or has anyone had a similar prob and would like to help me out please?
thanks,
dan
Mr. DIY
mrbacardi is offline   Reply With Quote
Old 06-03-2003, 10:10 AM   #2 (permalink)
View kocho's Photo Gallery
Re: changed springs, but rattling noise in the right rear
thanks,
dan
Did you allign the notch in the strut mount with the notch in the strut shaft? Another possibility is that the end-link on the sway bar is not tight enough. Or that the center or other nuts on the strut mount are loose - they may have worked themselves loose. Use some thread-locking compound of you re-install... Basically, you need to re-torque everything...
kocho is offline   Reply With Quote
Old 06-03-2003, 11:12 AM   #3 (permalink)
Bollywood Boy
mrbacardi's Avatar
actually i found the problem, when i put the rubber piece on the strut shaft, i put it in upside down, and that's causing the rattling cause it doesn't make a good seal with the top cover, it will take about a couple hours of work to fix it, but i guess that's how i learn hehe
thanks anyways,
dan
Mr. DIY
