Electrical Problems Following Deck Install. Advice wanted! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 04:41 AM   #1 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Unhappy Electrical Problems Following Deck Install. Advice wanted!
Hello,
After recieving a new CD player for Xmas, I immidiately proceeded to install it in the Camry (1995) before we drove to the mountains for some snowboarding.
I was in a rush (got it done in 15 minutes) but unfortunately I cut the whole old hardwired bundle at once. This shorted the constant +12V BAT supply wire with chassis ground wire.
So I damaged that circuit which supplies constant power to the CD player. The dome light does not work, and the dash digital clock doesn't work as well. Furthermore, I'm getting a slight whine from behind the fuse panel.
I've checked every fuse in the fuse panel and I don't see any blown fuses. I ran a new fused line to the deck so now the CD player works wonders, but I've yet to dig into this new electrical fault.
Before I get my hands dirty, has anyone else made this careless mistake and had this problem happen? and care to shed some solution before I tear the whole interior apart?
I've definitely learned my lesson about rushing things, but now I'm focused on fixing this.
Keep is offline   Reply With Quote
Old 12-27-2006, 07:46 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check Dome and Cig/Radio fuses.
Old 01-05-2007, 10:10 AM   #3 (permalink)
View Changs96Camry's Photo Gallery
Did you check the mini fuses that are in housing that are by the battery and intake box? Theres a small 30A (green) there. It kind of sounds like a problem I had when I was messing with wiring.
'96 Camry LE: 2.2L Stock As F@#$
Audio: Alpine MP3 HU, Kenwood 600watt Amp (Soon to be Kenwood 1000watt), Two 12inch Infiniti Reference in a MTX Box
Misc: Tinted, Hella Bulbs, Blue interior neons, other bullsh!t moddies
Changs96Camry is offline   Reply With Quote
Old 01-05-2007, 04:52 PM   #4 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Is there a reason you didn't buy an install harness?
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
ECHO model advice wanted cruizing Yaris, Vitz and Echo Forum 9 02-23-2006 06:43 PM
Considering a Prius: Advice Wanted shbcjb Prius Forum 1 02-22-2006 08:38 PM
eLECTRICAL pROBLEMS W/ 1991 COROLLA ib3kidsdad Archived Corolla threads 3 02-22-2005 03:52 AM
Electrical problems Kaliman Camry & Solara Lounge 0 11-20-2004 08:34 PM
electrical problems eyz closd MR2 Forum 7 01-24-2004 12:45 AM
