Power Steering Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2006, 09:10 PM   #1 (permalink)
Gameroom cash: $169185
iTrader Score: 6 reviews
View haux's Photo Gallery
Can anyone tell me how to change the power steering fluid on a 2000 Camry 2.2L?
haux is offline   Reply With Quote
Old 12-29-2006, 01:45 AM   #2 (permalink)
View toyomoho's Photo Gallery
Remove the upper return hose going from the pump to reservoir, start engine and let the pump to force the fluid out. Add fluid but don’t run the pump without fluid. Stop engine and refill if reservoir gets to low. Keep adding fluid until the outgoing fluid is clear.
Or over time use a turkey baster or similar to remove as much fluid from the reservoir as possible and refill with new fluid.
Old 12-29-2006, 02:00 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Look in the FAQ sticky. There is a DIY posted.
2007 Camry 2.4L 5M
Old 12-29-2006, 02:16 AM   #4 (permalink)
In the second to last picture in that DIY, what is the point of connecting a hose to the reservoir inlet?
Old 12-29-2006, 02:26 AM   #5 (permalink)
Probably to prevent fluid from coming out of the opening when you pour new fluid in the reservoir.
2007 Camry 2.4L 5M
Old 12-29-2006, 02:36 AM   #6 (permalink)
Maybe, but I figure you would re-attach the original hose before re-filling the reservoir.
Old 12-29-2006, 02:47 AM   #7 (permalink)
Yes, defnitely. After you flush everything, you would take the blocked off hose off and put the inlet hose back.
2007 Camry 2.4L 5M
Old 12-31-2006, 12:32 AM   #8 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
And from left field - newbie
Newbie here with a 2000 4cyl :
Link here to 4Runner forum has a good flush / bleeding write up. NOTE the 2nd / additional bleed turning steering lock-to-lock with the wheels on the ground. He does'nt explain why but IMPORTANT - it is to work the pump harder - to completly bleed.
http://www.yotatech.com/showthread.p...steering+flush
alotawatts is offline   Reply With Quote
Old 01-05-2007, 12:22 AM   #9 (permalink)
View marc780's Photo Gallery
I suck out my brake fluid and power steering fluid with a turkey baster every so often then refill. (Thx toyo) It is easy to do and good enough unless it is really dirty. I dont want to be unscrewing hoses etc. that dont need it, you are just making more trouble and work for yourself - i have learned this the hard way.
Old 01-05-2007, 01:55 AM   #10 (permalink)
The turkey baster method works surprising well! My dark PS fluid is now staying clear and red.
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
Power Steering Fluid Question ericcyl Camry & Solara Lounge 12 10-15-2006 09:53 AM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
how often do you change your power steering fluid? 01loadedLE Archived Corolla threads 5 09-20-2005 01:26 PM
Power Steering Checklist help blazin_azn MR2 Forum 14 06-13-2005 09:31 AM
