Changing Fuel Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2006, 09:45 PM   #1 (permalink)
Gameroom cash: $169185
iTrader Score: 6 reviews
View haux's Photo Gallery
When I change my power steering fluid on Monday, I would also like to change my fuel filter.
Does anyone have a good link to the procedure? Or someone can just give me some direction on what needs to be removed, and how to make sure there is no pressure that will pump fuel everywhere.
haux is offline   Reply With Quote
Old 01-01-2007, 02:30 AM   #2 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
use the search function it has been talked about already.
felonyr301 is offline   Reply With Quote
Old 01-01-2007, 06:59 AM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
yup
skewe is offline   Reply With Quote
Old 01-01-2007, 11:15 AM   #4 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Fuel Filter replacement
Don't put the key in the ignition. You don’t want to make the pump turn on. If you are not used to working in an engine compartment or leaning over a battery, you can disconnect the negative battery cable and cover the battery with a dry towel or fender cover.
Take off the air duct assembly and move it aside. Clean the debris from the air box and replace the air filter if you like. There’s nothing wrong with taking off the bottom part of the air box to get more room to work, plus it allows you to just dump out the stuff that's lurking in the box. Have a can of throttle body cleaner handy and clean all around the butterfly valve, reaching in as deep as your middle finger can reach with a clean shop rag wrapped around it. I like to clean the IAC at the same time on most cars.
Loosen the banjo bolt fitting on the top of the fuel filter, near the left strut tower. You can wrap a cloth around the fitting if you like to catch any spurting fuel. Now, you have depressurized the system. Chances are, if the car is sitting from the night before, there will be very little pressure there.
You will need a flare nut wrench for the bottom tube fitting to prevent the nut from being damaged. A conventional wrench will “round off” a tube fitting very easily, because the nut distorts under the forces usually applied to solid fittings. I found it much easier to use a flare nut "crow's foot" on the end of a 3/8" extension (maybe 18" long) and a long handled 3/8" ratchet to break the bottom fitting loose. A snap-on "flank drive" or a similar design works very well on tube nuts, because it puts no force on the corners of the hexes.
Spray some penetrant, like PB Blaster, into the area where the tube goes into the nut, and on the exposed threads of the nut going into the fuel filter. The penetrant helps reduce the possibility of the nut remaining frozen to the steel fuel line, particularly in areas where road salt is used. If the line looks like it wants to turn with the nut, stop forcing it and apply more penetrant. Tap on the fitting to get it to wick along the threads and deep into the fitting along the line. Let it sit for a while, and come back to it. If you have to, loosen the bracket clamp and turn the filter while holding the nut and line. The one situation you DON'T want is to twist the steel line. As I mentioned in another post, we used to stock these lines because new techs would ruin them.
Work smarter, not harder.
There are larger hexes built into the fuel filter to keep it from turning, so put the proper open-end wrench on such a spot and have someone help you, or brace the holding wrench against some firm object so you can put turning force against it as the fuel filter tries to turn as you put force on the tube nut. The bracket that holds the fuel filter is generally not strong enough to take the force of breaking the tube fitting loose.
Looking “up” at the fuel filter from below, you are turning counterclockwise to loosen the tube nut. If you do all this from above (looking down from the engine compartment) you will appear to be turning the tube wrench (or “flare nut” wrench) clockwise.
You can use the red plastic inserts that seal the new filter during shipping to keep fuel from running out of the old filter. From below, the fuel will run along your arm to your armpit. It burns.
With the two fuel connections removed, you can take the entire bracket and filter off the car (10 mm bolts) and install the new filter into the bracket, orienting it the same way as the old so the two metal fingers that position the banjo fitting are in the same relative position. There is also a ridge in the side of the filter to help you get this right, and a long screw-clamp to hold the filter in place in the old bracket. Before screwing the tube fitting into the bottom of the filter, I like to take some anti-seize and smear it on the tube, with the nut pulled back from the flare, and I put a little on the threads, as well. That way, it’s easier to break everything free next time.
Get the tube fitting started first, and make it finger tight before fitting the bracket to the car. That way, you can wiggle the filter around to get the threads lined up. Then once the bracket is installed you can tighten the flare nut fitting with the two wrenches and install the banjo bolt with the new washers that came with the filter.
Reinstall the air duct assembly, start the engine, and check for leaks.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-01-2007, 10:28 PM   #5 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
Another way to depressrise the system as per my Haynes manual is to take out the 30 AMP fuel pump fuse, remove the fuel filler cap, and start the engine until it stalls... and then turn the ignition off. Im not sure, but going at it via the banjo bolt may lead to alittle to much fuel coming out for some peoples likings... just a tip
Aussie_Camry is offline   Reply With Quote
Old 01-01-2007, 10:38 PM   #6 (permalink)
You could do it that way, but shop experience suggests it's not necessary. Two or three thousand filter changes lead you to write your own book, lol!
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Question on fuel filter replacing tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 36 05-14-2008 12:02 PM
GM to launch world's largest fuel cell fleet in '07 dsmnick General Discussion 1 09-17-2006 02:54 PM
1998 Corolla - Where to buy the fuel filter that's under the hood? Anthony1 Archived Corolla threads 7 01-05-2006 03:47 PM
