Jest had a head gasket replaced
just got my gen 2 back from getting the head gasket done
Toyota Camry To check out headgasket. Remove manifolds, timing covers etc. Clean up head and block. Fit new headgasket set and reassemble. Fit new distributor cap and full set of leads. Fit new thermostat and refill with coolant. Add engine flush to motor, change oil and oil filter. Clean out air filter. Cheek fuel filter. Add injector clean to fuel tank. Add Wynns engine supreme to motor. Test drive. Parts:-
Headgasket Set $150.00
Thermostat $25.50
Distributor Cap and Lead Set $172.00
Coolant $22.50
Engine Flush $11.95
oil $17.50
Oil Filter $8.50
Injector Clean $11.95
Engine Supreme $11,95
Consumables $6.00
GST: Total lne GST: Balance Due: $716.23 $71.62 $787.85 $787.85
and now i have a rettel caused by 2 nust missing off the exhaused and it is being held on by 1 nut! im getting that fixed 2morro.
what do you think about the cost? it is in australian $$$
MalooMAN
Gen 2
115HP
stock everything :-(
CHECK IT OUT!
http://members.cardomain.com/malooman
