5SFE, what blocks swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 09:12 AM   #1 (permalink)
View a2gsx's Photo Gallery
Sorry if this thread has been beaten to death, but I searched and couldn't find what I was looking for.
I have a 98 Camry with a 5SFE. It threw a rod out the front of the block. I need a shortblock, but what can I use? I know 98 was the start of a new Generation, but will any of the older engine blocks work? I am having some trouble finding a 98 or newer engine for a price I'm willing to pay considering I only need the bottom half. Thanks in advance,
Ryan
a2gsx is offline   Reply With Quote
Old 01-15-2007, 11:04 AM   #2 (permalink)
View CamZilla's Photo Gallery
Old block fits in perfect me and a bud swaped one into and old (1998) 423000km taxi he got. Use a 1992 5sfe block we had rebuild at school.
CamZilla is offline   Reply With Quote
Old 01-15-2007, 12:52 PM   #3 (permalink)
Gameroom cash: $304355
I don't know the cause of the thrown rod in your case, but are you familiar with the oil sludge problem (Toyota calls it "oil gelling") of the generation 4 5SFE engines? Toyota sent out extended warranty letters to most owners. It has been covered many times on this forum. If your problem was the result of oil sludging and you are under the mileage limit (don't remember if it was 120,000 or 150,000 miles), Toyota might cover the cost of your repair. Do a search. It might be worth your time.
Mike
Old 01-16-2007, 06:38 AM   #4 (permalink)
Thanks for the info.
Were there any perticular parts you needed? Flex plates? Mounts? or was it a 100% bolt up fit?
This would work out very well if I can use a block from an early 90's car. Those motors seem to be highly available and very cheap.
As for the warranty, I bought the car broke. It went to the dealer and was not covered. I think under this situation Toyota would probably not help me make a proffit on this 130K old car.
Ryan
Old 01-16-2007, 12:52 PM   #5 (permalink)
Ryan,
In your case, I am affraid you are correct. Thanks for responding and clarifying that point.
Mike
Old 01-17-2007, 10:34 AM   #6 (permalink)
So is this confirmed by anyone else? (I just like to get input from more than one person whenever possible) Is there anything I will need except a 5SFE block to put into my 98 and a upper engine gasket set? If this is all I need I'll be hitting the ground running with this project.
Thanks,
Ryan
Gen 3 5SFE to 3VZFE direct Swap Questions. ASG14 3rd & 4th Generation (1992–1996 & 1997–2001) 16 11-23-2006 08:29 PM
motor swap, from 5sfe to which motor? dchriste 3rd & 4th Generation (1992–1996 & 1997–2001) 12 11-22-2006 02:27 PM
JDM 5SFE into 96 Camry swap Isaac-1 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-30-2006 07:01 PM
Swap early 5SFE into later Camry ? Mid-Tom 3rd & 4th Generation (1992–1996 & 1997–2001) 7 04-03-2005 03:35 PM
3SFE - 5SFE Head Swap dynamictuner Celica Forum 1 09-07-2003 09:43 PM
