A104E tranny question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2003, 09:56 PM   #1 (permalink)
View 90camryV6's Photo Gallery
is there any way to change the gear ratio's of the tranny? and is it computer controlled? thanks.
90camryV6 is offline   Reply With Quote
Old 06-10-2003, 10:31 PM   #2 (permalink)
also, is there any way to control the shifting of the gears? i.e. some type of sportrongic, steptronic control
Old 06-11-2003, 06:21 AM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
There is no way of changing the gear ratios on an automatic transmission because the transmissions is controled by clutches and bands. As for it being electronically shifting yes that is what the E stands for int he tranny code.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 06-11-2003, 10:56 AM   #4 (permalink)
so would there be any way of controlling the shifting? like a sport shift or anything?
Old 06-11-2003, 04:08 PM   #5 (permalink)
SCCA Tech Services
you can change when it shifts and how hard it shifts you can also change when it engages with a different stall convertor but with the money you spend on all that you would be better off putting a manaul tranny in it and plus the manual tranny will be more reliable.
Brian Harmer
