97 camry will start and die - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2007, 10:23 PM   #1 (permalink)
View kmurali70's Photo Gallery
i have a camry 97 v6 model with 100k miles.
For the first time, i am having starting problems yesterday in the parking lot.
I started the car and then after the needle on the RPM hit 1 , it slowly went all the way to 0 and died. It happened 3 times and and i tried the 4th time , i managed to get on the freeway and drive home. Again the same happened at home.
What can be the reason, the "check engine light is also NOT lighted up.
i have already replaced the EGR valve, done engine flush , transmission flushes, changed timing belt., spark plugs have never been replaced and the last time at 90k the mechanic said it was ok,
What could be the reason ? should i just check at autozone first
Thanks
kmurali70 is offline   Reply With Quote
Old 01-23-2007, 11:19 PM   #2 (permalink)
View toyomoho's Photo Gallery
Guessing fuel system problem. The link below provides access to a Gen_4 service manual with a detailed diagnostic section. Have Autozone check for codes. Also check previous posts listed at the bottom of this page.
http://oregonstate.edu/~tongt/camry
Old 01-23-2007, 11:31 PM   #3 (permalink)
View marc780's Photo Gallery
I'm thinking you may have the good old dirty-idle air control valve problem. worth investing $4 in a can of sea foam or throttle body cleaner to try to clean it before changing any more parts, and its very easy to do.
http://www.toyotanation.com/forum/t157470.html
Old 01-27-2007, 09:17 PM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
probably your MAF sensor. I unplugged mine on my 05 Camry for shits and giggles once, the car stalled right out.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 01-28-2007, 12:09 AM   #5 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Do the procedure for cleaning the IAC.
Have AZ pull the codes for thoroughness.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-05-2007, 08:45 PM   #6 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
the car wouldnt stay on
my car starts without it but dies 1 second after on
try cleaning your TB IAC
maybe fuel pump????
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 03:44 PM
98 Camry poor idle upon start leasure23 3rd & 4th Generation (1992–1996 & 1997–2001) 8 11-25-2006 04:52 PM
90 Camry Strange Start/Stall Problem sroger007 1st & 2nd Generation (1983–1986 & 1987-1991) 7 10-10-2006 02:25 PM
94 Camry Need Help from the PROS cato47 3rd & 4th Generation (1992–1996 & 1997–2001) 0 06-17-2004 11:15 PM
