Steering wheel clicks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2007, 01:10 PM   #1 (permalink)
View rleescott's Photo Gallery
2004 camry xle 4 cyl, has developed a click that I feel and hear when turning the wheel. No noticable steering issues. The noise is transmitted to the center of the steering wheel and is like a tap or hitch or click. Anyone know what this means?
rleescott is offline   Reply With Quote
Old 01-26-2007, 01:39 PM   #2 (permalink)
View keithy's Photo Gallery
did you just replaced your struts?
keithy is offline   Reply With Quote
Old 01-26-2007, 01:51 PM   #3 (permalink)
Thanks for the reply. No repair work has been done. It only has 15000 miles.
Old 01-26-2007, 02:16 PM   #4 (permalink)
I have a similar sound on my steering wheel, but I think my problem was because the strut shaft was not alligned properly with the mount. but since you have not had struts/springs change, I doubt it is the same prob.
Anyways, you might want to check your cv joint.
Old 01-26-2007, 02:50 PM   #5 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
it's a defect... take it to the dealer and they'll replace the steering column assembly under warranty...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 01-26-2007, 04:21 PM   #6 (permalink)
Thanks for the info. Can you explain how you know this, please?
Old 01-26-2007, 05:30 PM   #7 (permalink)
i had the same problem with my 03 (the steering wheel squeaked and i could feel a vibration in the accelerator), and i assume that's what you're referring to... when i took it into the dealership they replaced the steering column assembly for free... so i imagine there must have been a TSB for that particular problem...
Old 01-27-2007, 02:07 AM   #8 (permalink)
View toyomoho's Photo Gallery
The U-joint in the steering column may be binding and making noise, Toyota has a TSB on this. You can see the joint by looking between the trans and firewall.
Old 01-27-2007, 12:02 PM   #9 (permalink)
Thanks for the help, all. I see the steering shaft coming thru the firewall and attaching to the steering rack. I see no fluid leekage. Should I see something abnormal there?
Old 01-27-2007, 10:29 PM   #10 (permalink)
No, the joint is bare and open to the engine compartment. You should be able to see the U-Joint where the steering shaft attaches to the rack and pinion housing. Most likely you will be only able to hear the noise, not see the problem. Have someone turn the steering wheel while you look and listen in this area.
Old 02-07-2007, 08:45 AM   #11 (permalink)
View fabio's Photo Gallery
steering wheel clicks
If it is a constant "click-click-click" it may well be a UV joint that needs replacing.
I had a similar problem with my Corolla, replaced the UV joint and that was the problem.
fabio is offline   Reply With Quote
Old 02-13-2007, 08:31 PM   #12 (permalink)
View flaterp's Photo Gallery
I have an '03 4cyl ATX but only notice the click occasionally during a turn. It's more noticeable when I'm driving over a bump. Do these cars have steering struts/stabilizers? It feels like a loose linkage or joint. The wheel shimmies slightly during the click as well. Any suggestions?
flaterp is offline   Reply With Quote
Old 02-17-2007, 08:41 PM   #13 (permalink)
View Sk2nrz's Photo Gallery
I remember seeing a few cars come into the dealership with the same type of clicking from inside the steering wheel. The issue was something with the airbag (which is why its coming from the center of your steeringwheel) It was NOT a threat to the driver just some kind of binding around the wiring that had come loose causing it to hit a certain spot in the steering wheel when turning.
Sk2nrz is offline   Reply With Quote
Old 02-19-2007, 12:43 PM   #14 (permalink)
Hmm, interesting. I hadn't heard about that. I'm not sure if the sound is coming from inside the steering wheel though. The sound itself is very faint if audible at all, but the most noticable sign is from the physical shimmy/vibration. Since the steering wheel is mechanically connected to many other components, it's a difficult to determine the problem. Thanks for the input!
Old 02-21-2007, 09:28 PM   #15 (permalink)
View deekay140's Photo Gallery
theres a tsb on the car. its the lower steering shaft joint. (Between the rack and column)
it only has a 3/36 warranty. you can try to torque down the 12mm bolt at the rack. It will quiet it down some, but will only be temporary.
the part number you need is 45220-33260
deekay140 is offline   Reply With Quote
Retrofit steering wheel controls ... afphinfan 2nd Generation (2005+) 8 04-05-2007 04:37 AM
steering wheel whiteae92 Archived Corolla threads 7 05-06-2006 10:16 PM
steering wheel whiteae92 Archived Corolla threads 0 04-08-2006 11:35 PM
leather steering wheel rewrap? ea8631 Celica Forum 2 01-12-2005 09:21 PM
