IM DOWN........please help asap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2003, 11:30 PM   #1 (permalink)
View celica/camry's Photo Gallery
ok my 5sfe has no power untill like 4 to 5k rpm
ive replaced all the ignition parts
if the timing belt was going would the timing be really off..thats what my dad says it is any way.....if i try to floor car befor 3500 rpm it almost stalls...also it has a bunch of wite smoke comming out everynow and then
"i got a toy on sum alloys boy"
celica/camry is offline   Reply With Quote
Old 06-15-2003, 12:16 AM   #2 (permalink)
The Asian Sensation
View Xevuhtess7's Photo Gallery
the white smoke might be steam? what does it smell like?
Xevuhtess7 is offline   Reply With Quote
Old 06-15-2003, 12:36 AM   #3 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
http://www.toyotanation.com/showthre...threadid=17672
maybe its the same situation...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 06-15-2003, 07:55 PM   #4 (permalink)
ok...to anser sum....i replaced everything cept the distributor and rotor
i was testing the car with the air hose disconected
car is bone stock
cept walmart hub caps
could use a oil change
flushed colant system a week ago
i need to get a guage
i dont have anything to check code
when this all hapened my dad was driving it....he said the car sorta jumped, broke the front engine mount and then started runnin like crap.
oh yeah i havta choke the car to get it to start (put hand over throttle body) and it idles ok....but after it runs for awhile it drips oil on the ground slowly every 15 to 20 seconds....but the car didnt run low on oil
Old 06-15-2003, 07:58 PM   #5 (permalink)
oh the white smoke....when i got out of the car and stop panicing...i noticed it smelled like burning rubber ....
also my dad said the car ran hot during all this and strted shaking but when i tested it , it didnt run hot, also i replaced all the motor mounts
Old 06-18-2003, 07:41 PM   #6 (permalink)
im getting closer to finding out whats wrong with my car....oil is drippin from the timing belt cover ...any idea where its coming from (i havent had the time to take cover off yet)
Old 06-18-2003, 07:43 PM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
clogged fuel filter or other fuel related issue?
Phi is offline   Reply With Quote
Old 06-18-2003, 09:18 PM   #8 (permalink)
maybe.....but wouldnt i smell gas or the car wouldnt start...but what does that havta do with oil
Old 06-18-2003, 10:31 PM   #9 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Blow head gasket maybe? Find out where the oil's leaking from, then the answer will probably be apparant.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
