What to do, to get better/stronger heat? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2007, 03:10 PM   #1 (permalink)
Hi.
View mystickid's Photo Gallery
4th Generation What to do, to get better/stronger heat?
My car has 74K and runs great and smooth.
However, it takes a good fifteen minutes of driving to get the heat "Hot enough".
I ride in many of my friends cars, even old ones that give off really HOT heat in just five minutes.
Is there anything I can do to make my car give better/hotter heat quicker?
mystickid is offline   Reply With Quote
Old 01-30-2007, 03:16 PM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
do you have a v6 or i4?
nodrogkam is offline   Reply With Quote
Old 01-30-2007, 04:25 PM   #3 (permalink)
Gameroom cash: $304355
Change the thermostat. It's probably opening up a bit early or is stuck slightly open. Use a Toyota OEM thermostat. They are around $15.
Mike
Old 01-30-2007, 05:37 PM   #4 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
Mike's right. Thermostat's beginning to fail. Any symptom of it would be the temp gauge reading cold when on the freeway
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 01-30-2007, 05:47 PM   #5 (permalink)
nodrogkam's Avatar
do both your camry's heat up fast?
say i leave on a cold night about 35F, it takes about 10 minutes for the heat to get pretty warm and 15 to reach its max heat (depending on if i drive city or go right on the highway).
This is the same with my 98 camry and our 05 HL both v6.
however i take our little 01 i4 corolla out and its fully warmed in 10 minutes or less. What gives? Smaller radiator?
Temp readings work fine on all 3 cars.
Old 01-30-2007, 05:54 PM   #6 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
It takes about 5 minutes for my heat to come out warm in my car, and its around 5-25F here during the day.
geoff5093 is offline   Reply With Quote
Old 01-31-2007, 11:25 AM   #7 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
i need to look into doing something as well. i have a 40 minute commute in the morning and since i listen to the radio, i rarely use turn the fan to 3 and never to 4. so at the 2 setting, my car never gets really warm (unlike mt previous vehicles) by the time i get to work.
Old 01-31-2007, 12:04 PM   #8 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
I allow a minimum of three minutes of running before driving. I also keep the heater set to "cold" to keep all heat in the block to warm the engine faster. Don't have any AC fans running either, that may have a chance at cooling the radiator in some configurations.
Good move on the thermostat, too. Genuine toyota. An open 'stat will keep the engine from warming up, and you will use more fuel.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-17-2007, 09:25 AM   #9 (permalink)
View marc780's Photo Gallery
The old timers used to block the radiator with a thin piece of wood or cardboard in cold weather to make the engine heat up faster. But of course you'd want to remember to pull out the cardboard on a long drive though.
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 02:29 PM
help no heat imasmrt1 Celica Forum 5 11-18-2006 09:38 PM
its cold, how's your heat? mazdaverx7 3rd & 4th Generation (1992–1996 & 1997–2001) 16 10-26-2006 06:34 AM
2005 Tacoma Double Cab NO HEAT tooley 2nd Generation (2005+) 2 02-01-2006 04:38 PM
No heat, and it's damn cold. yodanoob Archived Corolla threads 3 11-23-2005 07:36 PM
