5s-fe ecu diagram? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2003, 11:02 PM   #1 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
5s-fe ecu diagram?
I'm tring to find the wire diagram for our ecu so i can install my new rev meter. Unfortunately the wire diagram provided from my hayne manual sux butt. can someone help me out or know what color is what?
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 06-18-2003, 05:52 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.geocities.com/MotorCity/P...Pins_5S-FE.gif
"Skoolin' the unlearned!"
Old 06-18-2003, 08:21 AM   #3 (permalink)
Newbie
smokey8890's Avatar
"We're sorry, but this page is currently unavailable for viewing.
thanx anyways
Old 06-18-2003, 08:44 AM   #4 (permalink)
View Deep's Photo Gallery
click
http://www.geocities.com/MotorCity/P...epix/drawings/
then click
Deep is offline   Reply With Quote
Old 06-18-2003, 09:29 PM   #5 (permalink)
Newbie
smokey8890's Avatar
Originally posted by Deep
click
then click
thanks alot guys! you saved me $100
Old 06-18-2003, 09:52 PM   #6 (permalink)
Newbie
smokey8890's Avatar
could you guys find the RPM wire?
Old 06-18-2003, 10:02 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Nope.
You can get it off the ignitor though. On the gen 2's its the black wire. I'm not sure about gen 3's, but its probably also the black wire.
Theres IGF and IGT in the ECU diagram, but i'm not sure what they do.
Old 06-19-2003, 06:56 AM   #8 (permalink)
Newbie
smokey8890's Avatar
so you ran your off your igniter? if it is the IGF then it would be the same as the 4a-ge
Old 06-19-2003, 07:40 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
No.
I'm just saying that the black wire on the ignitor is the tach / rpm signal.
If you have a DMM you can check for continuity between the black wire on the ignitor and IGF or IGT on the ECU.
Old 06-26-2006, 07:02 PM   #10 (permalink)
View 2drcam's Photo Gallery
here try this. it is probably the best diagram out there.
http://3sgtecamry.com/Info_and_Tech_..._ECUPINOUT.htm
2drcam is offline   Reply With Quote
