halfshaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2007, 05:55 PM   #1 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
halfshaft
Halfshaft
REMOVAL & INSTALLATION
Avalon, Camry and Camry Solara
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable. On vehicles equipped with an air bag, wait at least 90 seconds before proceeding.
    • Front fender apron seal
    • Transaxle fluid
    • Tie rod end from the steering knuckle by removing the cotter pin and nut. Separate the tie rod from the steering knuckle.
    • Stabilizer bar link from the lower control arm. Make note of the washers and cushions positions.
    • Lower ball joint from the steering knuckle. Push down on the lower control arm and separate the steering knuckle from the ball joint.
    • Cotter pin, lock cap and locknut holding the halfshaft to the steering knuckle.
    • Halfshaft from the steering knuckle.
    • Left halfshaft from the transaxle
    • Snapring from the halfshaft.
    • Right halfshaft from the transaxle
    NOTE: The lockbolt is located in the center of the halfshaft, near the dampener. To install:
  3. Install the right halfshaft to the transaxle, as follows:
    1. Coat the side gear shaft and differential case sliding surface with gear oil.
    2. Using snapring pliers, install the snapring to the halfshaft.
    3. Install the halfshaft and the bearing lockbolt. Lockbolt: 24 ft. lbs. (32 Nm).
  4. Install the left halfshaft to the transaxle, as follows:
    1. Install a new snapring to the inner spline of the halfshaft.
    2. Coat the side gear shaft and differential case sliding surface with gear oil.
    3. Install the halfshaft to the transaxle with the snapring opening facing down. The halfshaft should click into place when installing.
    4. After installation of the halfshaft, check that the halfshaft cannot be removed by hand.
  5. Install or connect the following:
    • Halfshaft to the steering knuckle, then install the locknut. Locknut: 217 ft. lbs. (294 Nm).
    • Lock cap and new cotter pin to the halfshaft.
    • Steering knuckle to the lower ball joint. Nuts and bolt: 94 ft. lbs. (127 Nm).
    • Stabilizer bar link to the lower control arm. Nut: 29 ft. lbs. (39 Nm).
    • Tie rod to the steering knuckle. Nut: 36 ft. lbs. (49 Nm).
    • New cotter pin to the tie rod end.
    • Wheel(s). Lug nuts to 76 ft. lbs. (103 Nm).
    • Transaxle fluid
Old 04-29-2007, 09:07 AM   #2 (permalink)
View marc780's Photo Gallery
This a very helpful post Abew330, but what model years and engines does it apply to?
Need to replace RH halfshalft. emerald_gen3 Camry & Solara Lounge 14 01-24-2009 05:44 PM
Halfshaft for 91 mr2 3S-GTE 91ghosttuner MR2 Forum 4 11-27-2006 09:20 AM
Halfshaft replacement, 91 Corolla jenniferimai Archived Corolla threads 17 08-02-2006 04:37 PM
Halfshaft Damper 91711Paul Tercel, Paseo, Starlet, and Sera Forum 5 04-26-2006 09:50 PM
