brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2007, 06:04 PM   #1 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
brakes
FRONT AND REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the wheels.
  3. Disconnect the brake hose from the caliper.
  4. Remove the bolts that attach the caliper to the torque plate. If applicable, hold the flats of the sliding pin with a wrench while loosening the caliper attaching bolts.
  5. Lift up and remove the caliper assembly. To install:
  6. Install the caliper and loosely install the bolts.
  7. Hold the flats of the sliding pin with a wrench, then tighten the bolts. On front calipers, tighten single piston types to 18 ft. lbs. (25 Nm) and dual piston types to 25 ft. lbs. (34 Nm). Tighten the bolts on rear calipers to 14 ft. lbs. (20 Nm).
  8. Connect the brake hose to the caliper, using 2 new washers.
  9. Fill the brake system to the proper level and bleed the brake system.
  10. Add brake fluid to the reservoir to fill to the correct level.
  11. Lower the vehicle to the ground.
Old 02-07-2007, 06:05 PM   #2 (permalink)
REAR DISC
REAR DRUM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
1995 Camry LE Soft Brakes kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-17-2006 06:33 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 04:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
