86 camry "door open" light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2007, 01:11 PM   #1 (permalink)
woodduck's Avatar
View woodduck's Photo Gallery
On my 86 Camry the "door open" light keeps blinking on and off as you are going down the road.Slamming the passenger door makes it go out temporarily. Does any one know where the sensor is located? There is nothing visible so it must be behind the panel. Any suggestions would be appreciated.
woodduck is offline   Reply With Quote
Old 02-09-2007, 10:35 PM   #2 (permalink)
View Kingdom934's Photo Gallery
The little 'sensor' that tells it if the door is open or close is in this little black rubber cap on the lower part of the door frame of the car. I'll get a picture.
Kingdom934 is offline   Reply With Quote
Old 02-09-2007, 10:53 PM   #3 (permalink)
woodduck's Avatar
Thanks---a picture would be great
Old 02-10-2007, 12:04 AM   #4 (permalink)
Took me a while...TV show caught my attention (which it rarely does since I don't watch TV)
REAR door
FRONT door
What I would check is to see if they are being pressed all the way down (indicates that the door is close hence the door light is off) when the door is closed. If it flickers while the door sensor is pressed in, you might need to check it as it might need to be adjuested/replaced from what I'm thinking.
Old 02-10-2007, 01:55 PM   #5 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Same problem here, i just stuck a plastic bag there left it overnight. Now its conformed to the door and my problem is solved. In other words i lust stuck a plastic bag there and its still there, has been for two weeks.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 02-10-2007, 07:26 PM   #6 (permalink)
woodduck's Avatar
Thanks guys, found the sensor right where you said it was. When it warms up a bit I'll try and adjust it.
Old 02-11-2007, 03:20 PM   #7 (permalink)
View André Wemmelund's Photo Gallery
You can´t ajust it. Just replace it if it doesent work properly.
(Well, ajusting is prossible, but probably wast of time)
André Wemmelund is offline   Reply With Quote
Old 02-11-2007, 05:57 PM   #8 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Clean it if possible / and make sure it's grounding well.
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
98 camry le v6: Trunk Lid light/ Back up lights not working, Problem and solution ihqazi 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-26-2009 01:01 AM
Need Ideas for 86 Camry Magog 1st & 2nd Generation (1983–1986 & 1987-1991) 8 10-12-2006 10:27 PM
How to change courtesy light in door and glovebox on 92 Camry fernicus 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-22-2005 08:20 AM
Camry BackUp Light and Gear Selector Light Out yli5 Camry & Solara Lounge 1 02-16-2005 10:31 PM
1990 Camry V6/AT - O/D Light Flashes yeravgjoe 1st & 2nd Generation (1983–1986 & 1987-1991) 18 02-14-2004 01:30 PM
