please only answer if you know wtf youre on about, the local mechanic had nfi, and also the toyota dealer doesnt know (no codes to pull and not enough road to test run)
whenever OD os off, i loose a lot of power, simple as that. doesnt matter what gear im in, but if OD is off, theres a lot less power then if the button is on. so clearly, theres something else other then just overdriving 3rd gear for extra economy going on. in 3rd the loss is so great that the rpms will actually drop slightly or just stop climbing at all. 0-60 is about 1.5-2 seconds slower with OD off.
g0t wtf?
