first time popping the hood, some basic questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2003, 09:12 PM   #1 (permalink)
The Asian Sensation
View Xevuhtess7's Photo Gallery
alright, after some extensive parallel parking lessons my dad gave me, i popped the hood and took a look around my 94 v6. the big black tube (like 5 inches diameter) to the right of all the cylinders that is at an angle, that is the intake right?
and two silver attachments towards the bottom of the cylinders are the exhaust headers right (3 tubes per set)
Xevuhtess7 is offline   Reply With Quote
Old 06-19-2003, 09:20 PM   #2 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Re: first time popping the hood, some basic questions
yeah that should be your intake, does it go to a "plastic box" if so that is your air box in which you air filter would be contained in...
3 tubes per set? no comprehenda senorita, speak egalisah motha'fuga! i think you looking in the wrong place... but mabey I think that cause your description is a 'lil' too confusing for me!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 06-19-2003, 09:56 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yup.
The silver cover your seeing is the heat shield for the exhaust manifold.
There should be 2 exhaust manifolds. One towards the front of car and one towards the rear by the firewall.
The exhaust manifold bolts onto the cylinder head.
If you want to learn about the engine and what parts are what pick up a repair manual for your car.
"Skoolin' the unlearned!"
Old 06-19-2003, 10:12 PM   #4 (permalink)
The Asian Sensation
oh those are the exhaust manifolds?
i circled what im talkin about in green (no this is not my engine or even my type of car, sorry for the small pic, just grabbed it off google)
Old 06-20-2003, 04:14 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Top is intake manifold.
Bottom is exhaust manifold (front).
Old 06-20-2003, 04:16 AM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
don't touch the one on the bottom after the car's been running
or else i'll have to give you a sign
-Nick
Nick is offline   Reply With Quote
Old 06-20-2003, 11:44 AM   #7 (permalink)
The Asian Sensation
so where would the exhaust headers be?
Old 06-20-2003, 06:27 PM   #8 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
You posted a picture of a four cylinder engine so you circled the exhaust and intake manifolds.
You are right the first time you have a V6 so there are two exhaust manifolds (aftermarket exhaust manifolds = headers) with three pipes each, making six total, one for each cylinder
P.S. = A stock exhaust manifold is shorter and tuned mildly to give you low-end torque for around town and good fuel economy.
An after market exhaust manifold is called a header (one header for an inline four or six and two for a V6 or V8 or V10, etc.) and it is longer to improve flow and reduce back pressure resulting in slightly less low-end power and fuel economy but higher over-all peak power.
Chris Corolla S is offline   Reply With Quote
Old 06-20-2003, 06:59 PM   #9 (permalink)
sargdesigns
I wasn't thinking about you having a 6 my bad bro... yeah those are your "headers" ... sorry....
Brandon
Old 06-20-2003, 11:03 PM   #10 (permalink)
View warlock's Photo Gallery
look at your pic XEVUHTESS7 see the upper green part the exhaust is under that. and the other set is the other green circale.there is not reason to play with the headers unless you are going terbo,if you dont know where thay are dont f#ck with them
warlock is offline   Reply With Quote
Old 06-21-2003, 02:09 AM   #11 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
No, he posted a picture of a v6.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 06-21-2003, 07:46 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Yeah the picture is of a V6.
Notice the 3 coil packs, engine cover, and intake manifold.
Old 06-21-2003, 02:45 PM   #13 (permalink)
The Asian Sensation
ok so they are both exhaust manifolds? then where does the air go in from?
by the way i did some more poking around the other day and i took apart the airbox. my filter was maaaaaad clogged! it was black with dust and dirt and had leaves pine needles and all sorts of road crap all inside it. i think its time to replace it
Old 06-21-2003, 04:03 PM   #14 (permalink)
Grenaded piston
88 LE's Avatar
No.
The top part is the intake manifold and the bottom is the exhaust manifold.
Take alook at the pic you posted.
The air gets sucked in through the airbox. From there it goes through the intake piping ---> throttle body ---> intake manifold ----> cylinder head (intake side) ---> combustion camber (where it gets mixed with fuel, compressed, and combusted) ---> out the cylinder head (exhaust side) ---> exhaust manifold ---> through the exhaust ----> then spewed out the tailpipe in the air.
Old 06-23-2003, 05:51 PM   #15 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
So I'm bored as hell and reading this thread, so I drew a picture for you.
I.M. = Intake Manifold
E.M. = Exhaust Manifold
So what you're seeing in your picture, on the top is the intake manifold, and on the bottom is the front exhaust manifold. The rear exhaust manifold is located beneath the intake manifold, so it's impossible to see in your picture. Then the two exhaust manifolds are joined together at the y-pipe, which I didn't label, and head to the cat, muffler, etc... all in one pipe.
http://www.imagestation.com/picture/...6/fbdac92f.jpg
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
