2000 4cyl Camry question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2007, 12:49 PM   #1 (permalink)
View 03highlander's Photo Gallery
I've got a really annoying squeak in my steering wheel when I turn. It sounds like there is probably a rubber boot that is rubbing on the steering wheel shaft. It has been so cold lately I haven't gone out in the garage to investigate. The noise is louder now that we are getting cold weather. Have any of you experienced this problem? Any remidies? I figure there has got to be an easy way to lube it to quiet it down.
Thanks in advance.
03highlander is offline   Reply With Quote
Old 02-15-2007, 12:59 PM   #2 (permalink)
View ToyotaDealer's Photo Gallery
it's a fairly common problem, most common in the camry's. remedied by using lithium grease or some form of lubricant on the steering shaft underneath the dash.
ToyotaDealer is offline   Reply With Quote
Old 02-16-2007, 07:44 AM   #3 (permalink)
View mdmm's Photo Gallery
Hi,
i have a similar problem with steering wheel.I am not a tech.Please let me know how and where to install any lubricant??.What is cheapest lubricant to use.??Thanks
mdmm is offline   Reply With Quote
Old 02-16-2007, 12:24 PM   #4 (permalink)
Originally Posted by mdmm
Hi,
look underneath the dash, where the steering shaft runs up through the firewall/dashboard. turn the wheel and listen for the squeeks, it's a real easy job, and once you're under there it's real easy to find.
as far as the cheapest lubricant to use, i can't say? we use Toyota white lithium grease, but that's because i work at a Toyota dealership which A. makes people happier that Toyota products are being used on their Toyota's, and B. is supplied to us
i dont know why any standard lubricant wouldn't work, or run it by your local dealership and have one of their hourly techs slap a spot of grease on it. we do it for free at ours, it takes less than 2 minutes to do and virtually nothing in grease, you just want something tacky so that it doesn't drip down and mess up the floormat/carpets.
Old 02-18-2007, 11:12 AM   #5 (permalink)
View marc780's Photo Gallery
I dont have this problem but lemme at least point you in the right direction, some people have been posting lately that it can be caused by the u-joints in the steering column running dry or worn out.
Toyota dealer i hate to disagree with you but i will. Lithium grease is petroleum based and is the wrong thing to use on anything rubber or neoprene, it attacks the rubber over time.
Use silicone spray or rubber grease only on your own car, unless you like changing the rubber boots on stuff.
Old 02-18-2007, 01:28 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
That rubber piece will not suffer any harm for the life of the car if you use White lithium grease, it is not functioning as a critical seal, just to keep large debris and you fingers from touching the u joint inside. Some silicone sprays will craze plastics, and that is depending on what carrier agent it is using.
Neoprene is very resistant to hydrocarbons.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-19-2007, 06:35 AM   #7 (permalink)
Thanks Alot Brothers.
Your Suggestions Helped Me. I Did And There Is No Noise Coming Out Any More.thanks
Old 02-19-2007, 12:52 PM   #8 (permalink)
Thanks a bunch! I'll look under the dash tonight.
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
2000 camry le 4cyl engine swap question... DJboozeAlot 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-10-2006 07:07 PM
Valve adjust 1999 4cyl. Camry joede 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-14-2006 10:28 PM
2000 4cyl Camry: Dreaded call from the mechanic xsnrg 3rd & 4th Generation (1992–1996 & 1997–2001) 28 08-01-2006 09:40 PM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
