windshield washer jet frozen - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 12:20 AM   #1 (permalink)
View frankierx's Photo Gallery
My windshield washer dispensers are frozen. I tried to brush them and they still wont dispense the fluid. Any suggestions?
frankierx is offline   Reply With Quote
Old 02-17-2007, 12:35 AM   #2 (permalink)
View toyomoho's Photo Gallery
Is the washer pump working? Check the posts at the bottom of this page. If really frozen apply some heat via a hair dryer and use a fluid with more alcohol.
Old 02-17-2007, 08:44 AM   #3 (permalink)
Yes, The washer pump must be working because the right jet is shơoting out a little bit of fluid, although at a misaligned direction due to frozen status I would believe. The left jet still doesn't shơot. I tried to poke a thread inside the hole and no luck in pushing it all the way. I could pull the car in the garage and apply heat with the hair dryer , but I am at someone else's house right now.
Old 02-17-2007, 08:53 AM   #4 (permalink)
Official TN user
Tuner571's Avatar
View Tuner571's Photo Gallery
If you bring it inside the garage and pour hot water on it that might help. Make sure that right after you do it you try to get the nozzles to work or the water may freeze again then hit it with a hair dryer to dry it off . Also are you using a different type of washer fluid in the winter, the kind that doesnt freeze.
95 Toyota Camry V6
http://www.cardomain.com/ride/2489322
Tuner571 is offline   Reply With Quote
Old 02-17-2007, 09:53 AM   #5 (permalink)
It is actually fluid from the summer that wasn't finished yet. I just emptied an entire container of winter fluid in the reservoir.
update: I brought the car into the garage. And not more than 5 minutes, the jets now shơot out fluid.
Old 02-17-2007, 08:45 PM   #6 (permalink)
View Sk2nrz's Photo Gallery
Try disconnecting the line at the nozel that is not working and see if you have fluid shoot out. If you have a stream then you know the problem lies with the nozel. If you still have nothing follow the washer line twords the pump and look for a break if the pump is working.
Sk2nrz is offline   Reply With Quote
Old 02-05-2008, 10:28 PM   #7 (permalink)
tug_slug's Avatar
View tug_slug's Photo Gallery
Im having this same problem with my 01 Tacoma, when the weather's warm the jets work fine but the minute it snows and the roads get sloppy, when I need them the most they dont work.
tug_slug is offline   Reply With Quote
Old 02-06-2008, 08:01 AM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
First, this thread is a year old, and second, this is the Camry forum not the Tacoma forum.
I don't know if this is an issue for Tacoma's or not since I don't have one, but if you want a definite answer you should ask there.
geoff5093 is offline   Reply With Quote
Windshield washer problem jc27 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-28-2007 08:52 AM
windshield washer and coolant 2020 1st Generation (2003-2008) 3 10-16-2006 05:28 PM
87 Camry Wagon, Windshield Washer Resivoir(s) curtisz 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-02-2006 01:14 AM
windshield washer system dutchcrunch Archived Corolla threads 3 08-04-2005 08:55 PM
windshield washer lights grapefury Camry & Solara Lounge 17 05-28-2003 10:49 PM
