Random Misfire Codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 09:43 PM   #1 (permalink)
View Sk2nrz's Photo Gallery
I was just sitting in a drive thru and had the check engine light come on. I pulled the codes and had 12 tripped codes each code was twice.
P0300 Random multiple cylinder misfire
P0302 Cyl 2 Misfire
P0304 Cyl 4 Misfire
P0306 Cyl 6 Misfire
P0174 System to lean (Bank 2)
P1150 A/f Sensor Circuit Range/Performance Bank2/Sensor2
All this sounds like a O2 sensor to me any ideas on which would be of great help. Also as I was driving home the check engine light flashed for about 5 seconds and then the Vsc and Trac Off lights came on. I know of 2 other camrys that have had the vsc and trac off lights come on within a few days of each other. Anyone know of any Tsb's on this issue?
I cleared the codes drove around for about 15 minutes and only once did the check engine light flash on and off but never stayed on. Thanks
Sk2nrz is offline   Reply With Quote
Old 02-18-2007, 09:47 AM   #2 (permalink)
View marc780's Photo Gallery
I cant tell whether your car is the kind that has a distributor cap or not (you dont say the model year or engine). The codes you mention sound like they are probably ignition related, so maybe it just needs a tune up.
If this engine has a distributor, inspect the cap and rotor; you may find them burned and needing replacement. Also check or replace the spark plugs if you haven't done that in a while. They could be burned, worn out, fouled, or have a wrong gap.
Old 02-19-2007, 02:38 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
from the codes that you popped, it sounds like the car must be running like ass
and my suggestion would be to check for vacuum leaks after the MAF- it sounds like your car is getting the wrong amount of air, and when the ecu compensates by either adding too much or too little fuel, it will either run super lean or super rich, giving both misfires and overheated o2 sensors
for a leak this big, check for a faulty throttlebody gasket- I found that mine was leaking like a seive at one point (as well as another huge leak) and it contributed to the exact same symptoms and codes that you pulled
HaHa
Old 02-21-2007, 09:31 PM   #4 (permalink)
View deekay140's Photo Gallery
what year is it?
deekay140 is offline   Reply With Quote
Old 04-22-2009, 03:33 PM   #5 (permalink)
View gcorolla99's Photo Gallery
this just suck when people don't post back their findings.
gcorolla99 is offline   Reply With Quote
Old 04-22-2009, 03:48 PM   #6 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Still no sense waking up old threads...
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Random misfire jthiemeyer 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-19-2010 05:34 AM
Random Cylinder Misfire?!? JiggaManX Archived Corolla threads 3 09-28-2006 07:07 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Misfire code(s) slcpunk Camry & Solara Lounge 4 09-22-2004 01:27 PM
help random misfire code 300 303 306 2000 4runner rover1 4Runner Lounge 4 08-29-2004 09:36 PM
